[Qgis-user] QGIS => Inkscape Issues
Andreas Neumann a.neumann at carto.net
Sun Aug 26 14:36:22 PDT 2012
Hi David,
You probably have to ungroup it (potentially several times).
Unfortunately the file structure of the exported SVG is not optimal.
Ideally there could be one group per layer with an id indicating which
group is which layer.
Hope this helps,
Andreas
Am 26.08.2012 21:02, schrieb David Fawcett:
> I have created a map in QGIS and exported it as SVG.  I am attempting to
> now edit and use the exported features in Inkscape.
> I am having some issues placing text on the vector paths.  It appears that
> Inkscape is treating the whole chunk of SVG exported from QGIS as one
> object.  When I attempt to select an individual street line in Inkscape, I
> get all of the features together.  I can use the path edit tool to modify
> an individual line segment.  I can also symbolize it independently.
> Does anyone have any experience with this?  Are there any good tutorials
> for QGIS => Inkscape?
> Thanks,
> David.
> Qgis-user mailing list
