[Qgis-user] question on the calculation of the distance between points
Giovanni Manghi
giovanni.manghi at faunalia.pt
Mon Aug 27 02:49:57 PDT 2012
The "standard NxT" matrix works fine here. Can you share a sample of
your data?
cheers
On Sun, 2012-08-26 at 22:35 +0200, Sergio Vignali wrote:
> Ok, but I can't see the results. When I open the csv file there are
> strange symbols. I use libreoffice.
> 2012/8/26 Giovanni Manghi <giovanni.manghi at faunalia.pt>
> Vector menu, distance Matrix tool
> On Aug 26, 2012 9:17 PM, "Sergio Vignali"
> <vignalisergio30 at gmail.com> wrote:
> Hello, maybe the question is common!
> I have a shp with different points and I want to
> calculate the distance between all the point. Is there
> a simple way to do it with QGis?
> Regards
> Sergio Vignali
> CERM Centro Rapaci Minacciati
> (Endangered Raptors Centre)
> Qgis-user mailing list
> Sergio Vignali
