[Qgis-user] question on the calculation of the distance between points
Sergio Vignali vignalisergio30 at gmail.com
Mon Aug 27 04:59:57 PDT 2012
I found the problem. I worked with a postgis vector and I obtained a
illegible csv file.
Now I have saved the postgis vector as a shp and the distance matrix works
well.
I have another question, the csv file return a distance as degree (true?),
but if I want a linear distance (m), how can I do?
2012/8/27 Giovanni Manghi <giovanni.manghi at faunalia.pt>
> The "standard NxT" matrix works fine here. Can you share a sample of
> your data?
> cheers
> On Sun, 2012-08-26 at 22:35 +0200, Sergio Vignali wrote:
> > Ok, but I can't see the results. When I open the csv file there are
> > strange symbols. I use libreoffice.
> > 2012/8/26 Giovanni Manghi <giovanni.manghi at faunalia.pt>
> >         Vector menu, distance Matrix tool
> >         On Aug 26, 2012 9:17 PM, "Sergio Vignali"
> >         <vignalisergio30 at gmail.com> wrote:
> >                 Hello, maybe the question is common!
> >                 I have a shp with different points and I want to
> >                 calculate the distance between all the point. Is there
> >                 a simple way to do it with QGis?
> >                 Regards
> >                 Sergio Vignali
> >                 CERM Centro Rapaci Minacciati
> >                 (Endangered Raptors Centre)
> >                 _______________________________________________
> >                 Qgis-user mailing list
> >                 Qgis-user at lists.osgeo.org
> >                 http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Sergio Vignali
Sergio Vignali
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120827/8c5f2230/attachment.html>
