[Qgis-user] Transforming Gauss-Krueger 3 to ETRS 89 UTM32N
Bernhard Ströbl
bernhard.stroebl at jena.de
Tue Aug 28 03:20:13 PDT 2012
Oh,
yeah, I think you are right. I was fixed on the 32000000 :)
Klaus, I found this link (in German):
https://www.geoportal-mv.de/land-mv/GeoPortalMV_prod/de/Geowebdienste/_faq/etrs89_zk_gis.jsp
Bernhard
Am 28.08.2012 11:03, schrieb Bo Victor Thomsen:
> Bernhard
> Shouldn't the false easting in the custom CRS be 32.500.000 ? The normal
> "false easting" for UTM is 500.000. The 32.000.000 must be added to this
> value.
> Regards
> Bo Victor Thomsen
> Aestas-GIS
> Denmark
> Den 28-08-2012 10:58, Bernhard Ströbl skrev:
>> Dear Klaus,
>> the transformation is correct. EPSG:25832 is defined without the
>> leading UTM-Zone (32) as the zone is part of the projection's
>> description. At least ome German "Bundesländer" however put the 32
>> into their ETRS89 data (no ides why, thus there is no EPSG-code you
>> can use for these data). You have to create a custom projection with a
>> false easting of 32000000.
>> Be sure there is a datum transformation performed otherwise your data
>> can be some tens of metres wrong or use the Beta2007 grid
>> Bernhard
>> Am 28.08.2012 10:36, schrieb Klaus mithöfer:
>>> Dear all,
>>> I have a problem transforming shape files based on Gauss-Krueger 3 (EPSG
>>> 31467) to ETRS 89 UTM32N (EPSG 25832). The problem is the eastern value.
>>> It has only 6 instead of 8 digits, the first two numbers are missing in
>>> ETRS system (e.g. 570873 instead of 32 570873). Could anyone give advice
>>> on how to do the transformation?
>>> Thank you
>>> Klaus --
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> __________ Information from ESET Mail Security, version of virus
>>> signature database 7422 (20120827) __________
>>> The message was checked by ESET Mail Security.
>>> http://www.eset.com
>> http://www.eset.com
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 7423 (20120828) __________
http://www.eset.com
