[Qgis-user] Transforming Gauss-Krueger 3 to ETRS 89 UTM32N
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Tue Aug 28 02:03:44 PDT 2012
Bernhard
Shouldn't the false easting in the custom CRS be 32.500.000 ? The normal
"false easting"  for UTM is 500.000. The 32.000.000 must be added to
this value.
Regards
Bo Victor Thomsen
Aestas-GIS
Denmark
Den 28-08-2012 10:58, Bernhard Ströbl skrev:
> Dear Klaus,
> the transformation is correct. EPSG:25832 is defined without the
> leading UTM-Zone (32) as the zone is part of the projection's
> description. At least ome German "Bundesländer" however put the 32
> into their ETRS89 data (no ides why, thus there is no EPSG-code you
> can use for these data). You have to create a custom projection with a
> false easting of 32000000.
> Be sure there is a datum transformation performed otherwise your data
> can be some tens of metres wrong or use the Beta2007 grid
> Bernhard
> Am 28.08.2012 10:36, schrieb Klaus mithöfer:
>> Dear all,
>> I have a problem transforming shape files based on Gauss-Krueger 3 (EPSG
>> 31467) to ETRS 89 UTM32N (EPSG 25832). The problem is the eastern value.
>> It has only 6 instead of 8 digits, the first two numbers are missing in
>> ETRS system (e.g. 570873 instead of 32 570873). Could anyone give advice
>> on how to do the transformation?
>> Thank you
>> Klaus --
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> __________ Information from ESET Mail Security, version of virus
>> signature database 7422 (20120827) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
> http://www.eset.com
