[Qgis-user] creating .gpx file strips out al the attributes
M.E.Dodd
m.e.dodd at open.ac.uk
Tue Aug 28 07:40:23 PDT 2012
The 'save as' command in qgis seems to strip out attribute data when creating files of certain sorts such as .gpx and also gives problems with .kml where the markers are not identified with any of the attributes. Are there any workarounds for these problems?
More detail on the .gpx issue, it will produce a .gpx file if you select 'skip attribute creation' but if you don't select this then it fails with the error message:
"Export to vector file failed.
Error: creation of field tree_id failed (OGR error: Field of name 'tree_id' is not supported in GPX schema. Use GPX_USE_EXTENSIONS creation option to allow use of the <extensions> element.)"
It appears to be quite a helpful error message except that I can't see anywhere to "Use GPX_USE_EXTENSIONS creation option"
Qgis 1.8 or 1.9 on windowsxp
The Open University is incorporated by Royal Charter (RC 000391), an exempt charity in England & Wales and a charity registered in Scotland (SC 038302).
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120828/d149a37b/attachment.html>
