[Qgis-user] creating .gpx file strips out al the attributes
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Tue Aug 28 08:23:13 PDT 2012
Write "GPX_USE_EXTENSIONS=YES" in the "OGR creation options", "Data
source" section
like this:
Remember to choose EPSG:4326 as the CRS. Thats the only CRS that the GPX
format formally support
Regards
Bo Victor Thomsen
Aestas-GIS
Denmark
Den 28-08-2012 16:40, M.E.Dodd skrev:
> The 'save as' command in qgis seems to strip out attribute data when
> creating files of certain sorts such as .gpx and also gives problems
> with .kml where the markers are not identified with any of the
> attributes.  Are there any workarounds for these problems?
> More detail on the .gpx issue, it will produce a .gpx file if you
> select 'skip attribute creation' but if you don't select this then it
> fails with the error message:
> "Export to vector file failed.
> Error: creation of field tree_id failed (OGR error: Field of name
> 'tree_id' is not supported in GPX schema. Use GPX_USE_EXTENSIONS
> creation option to allow use of the <extensions> element.)"
> It appears to be quite a helpful error message except that I can't see
> anywhere to "Use GPX_USE_EXTENSIONS creation option"
> Qgis 1.8 or 1.9 on windowsxp
> The Open University is incorporated by Royal Charter (RC 000391), an
> exempt charity in England & Wales and a charity registered in Scotland
> (SC 038302).
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120828/2c35fb1e/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120828/2c35fb1e/attachment.png>
