[Qgis-user] Fwd: wktraster with Postgis 2.0 in QGIS 1.9 on Linux Mint Maya
Mauricio de Paulo mauricio.dev at gmail.com
Tue Aug 28 12:29:00 PDT 2012
Hi, Brian and Etienne.
Well, GDAL 1.7.3 was one of the first efforts to read postgis raster,
back in the release candidate days. A few months before the release of
postgis 2.0 there was a major change in the raster storage and some code
was discontinued. GDAL 1.9.0 was the first release after postgis 2.0 was
released so it's the first version that is compatible.
Fortunately, vector data is a mature standard inside postgis and didn't
suffer any major changes that could break previous working code.
Even though we were all notified by these changes, some of our previous
work doesn't work with the current version. It was a huge improvement in
raster storage and metadata retrieval, so we have to cope with it.
I'm releasing the new plugin version with the weak loader tonight. It
should be enough to upload one untiled raster with no overviews to the
database.
I'm using ubuntugis' repositories. The gdal package available on it is
version 1.9.1 so you might want to try those binaries, since they work
pretty well.
All the best,
Mauricio C. M. de Paulo
Engenheiro Cartógrafo
Mestrando em Sensoriamento Remoto (INPE)
On 08/28/2012 04:17 PM, Brian Fitzgerald wrote:
> I'm showing GDAL version 1.7.3-6 in Synaptic... so that could be my
> problem... but wouldn't I also be experiencing loading postgis 2.0
> vectors?
> - Brian
> On Tue, Aug 28, 2012 at 3:01 PM, Mauricio de Paulo
> <mauricio.dev at gmail.com <mailto:mauricio.dev at gmail.com>> wrote:
>     Hi Brian,
>     I downloaded the sample data and imported to my database and it
>     seems to work pretty well. I'm using QGIS 1.8, postgis 2.0,
>     postgres 9.1.5, gdal 1.9.1 on ubuntu 12.04.
>     Sorry for my ignorance but what GDAL version is being released
>     with linux mint? I couldn't find anywhere online.
>     The plugin heavily relies on GDAL to perform the visualization so
>     you need the latest GDAL available to get a decent performance.
>     From my first tests I can say that GDAL 1.9.1 has greatly improved
>     performance and the next versions should improve even further. The
>     fastest visualization that I have achieved with version 1.9.1 is
>     with single tiled raster files. Unfortunately I wasn't able to get
>     GDAL to use overviews so far, but Jorge (GDAL's postgis raster
>     developper) is researching on this subject.
>     GDAL versions bellow 1.9 should not be able to read postgis 2.0.
>     Unfortunately, since postgis 2.0 release, the python loader was
>     discontinued in postgis source. Recently I have started to make
>     the necessary changes starting from the old code to get it to
>     work. I don't know if this is going to be a good solution but it
>     seems possible. I'm trying to avoid the platform-dependent
>     compilation that postgis' raster loader has in version 2.0 now
>     that it's being entirely written in C. In the future I should
>     probably release a simple uploader with the plugin, without all
>     those options until I'm certain that everything is working
>     according to the standard.
>     I'm copying this mail to the list to allow other users to find
>     this thread later.
>     On 08/28/2012 03:56 PM, Brian Fitzgerald wrote:
>>     PS - Im also unable to "load" raster data into PostGIS using the
>>     plugin... the icon is greyed out for some reason.
>>     - Brian
>>     On Tue, Aug 28, 2012 at 2:20 PM, Brian Fitzgerald
>>     <bkfitz at gmail.com <mailto:bkfitz at gmail.com>> wrote:
>>         Sure.
>>         I'm running Ubuntu Mint 13 Cinnamon with Postgres 1.9.5,
>>         Postgis 2.0. and QGIS 1.9.0
>>         I followed this install tutorial:
>>         http://linfiniti.com/2012/05/installing-postgis-2-0-on-ubuntu/
>>         I loaded the sample vector shapefile into my new 'training'
>>         database and opened it in QGIS with no problem.
>>         I loaded the sample raster data using the command in the
>>         tutorial, it loaded with no problems.  I ran the test query
>>         in the tutorial, no problem.  I went into QGIS to load the
>>         raster and got an error that referred to some missing python
>>         dependencies (i think it was the python-psycopg libs)... so I
>>         went to Synaptic and loaded the following:
>>         Installed the following packages:
>>         libjs-sphinxdoc (1.1.3+dfsg-2ubuntu2.1)
>>         libjs-underscore (1.1.6-1ubuntu2)
>>         python-dbg (2.7.3-0ubuntu2)
>>         python-psycopg2 (2.4.5-1)
>>         python-psycopg2-dbg (2.4.5-1)
>>         python-psycopg2-doc (2.4.5-1)
>>         python2.7-dbg (2.7.3-0ubuntu3.1)
>>         python3 (3.2.3-0ubuntu1)
>>         python3-dbg (3.2.3-0ubuntu1)
>>         python3-minimal (3.2.3-0ubuntu1)
>>         python3-psycopg2 (2.4.5-1)
>>         python3-psycopg2-dbg (2.4.5-1)
>>         python3.2 (3.2.3-0ubuntu3)
>>         python3.2-dbg (3.2.3-0ubuntu3)
>>         python3.2-minimal (3.2.3-0ubuntu3)
>>         I then came back to QGIS to open the raster and no longer get
>>         the python error... this time it brings up the "Load PostGIS
>>         Raster Layer" just fine and displays my sample raster.  I
>>         click on the raster name in the table and it puts it down in
>>         the "Table Name" input box.  I then click on OK and get a
>>         window that pops up saying "Could Not Load Layer".  I click
>>         ok to this and another window comes up that says:  "Could not
>>         load PG: dbname=training host=localhost user=postgres
>>         password=xxxxxx port=5432 schema=public table=srtm_4326
>>         mode=2".  When I click ok to this, the window diappears and
>>         nothing happens.
>>         I also tried one of our ortho geotiffs using the following
>>         command and get the same results:
>>         postgres at minty /home/rcgeoadmin/Temp $ raster2pgsql -s 4326
>>         /home/rcgeoadmin/Temp/979903.tif | psql training
>>         Processing 1/1: /home/rcgeoadmin/Temp/979903.tif
>>         Warning 1: TIFFReadDirectory:Unknown field with tag 33919
>>         (0x847f) encountered
>>         BEGIN
>>         NOTICE:  CREATE TABLE will create implicit sequence
>>         "979903_rid_seq" for serial column "979903.rid"
>>         NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit
>>         index "979903_pkey" for table "979903"
>>         CREATE TABLE
>>         INSERT 0 1
>>         COMMIT
>>         - Brian
>>         On Tue, Aug 28, 2012 at 8:24 AM, Mauricio de Paulo
>>             Hi, Brian.
>>             Could you please elaborate a little more about what were
>>             you trying to do and what raster configuration you were
>>             using? Is it tiled or untiled? One single raster file in
>>             the table? Did you build overviews?
>>             All the best,
>>             On 08/27/2012 07:00 PM, Brian Fitzgerald wrote:
>>>             ---------- Forwarded message ----------
>>>             From: "Brian Fitzgerald" <bkfitz at gmail.com
>>>             Date: Aug 27, 2012 4:57 PM
>>>             Subject: wktraster with Postgis 2.0 in QGIS 1.9 on Linux
>>>             Mint Maya
>>>             To: <wonder.sk at gmail.com <mailto:wonder.sk at gmail.com>>
>>>             I'm having problems loading a Postgis 2.0 raster layer
>>>             into QGIS 1.9 using your wktraster extension.
>>>             The menu comes up, but I get a "could not load layer"
>>>             Then a window that says:
>>>             "Could not load PG: dbname=training host=localhost
>>>             user=postgres password=topology4 port=5432 table= mode=2"
>>>             Any ideas?
>>>             Brian Fitzgerald, PMP, GISP
>>>             803.426.3469 <tel:803.426.3469>
> 803.426.3469
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120828/7751de16/attachment.html>
