[Qgis-user] Help cutter raster
Germán Carrillo carrillo.german at gmail.com
Wed Aug 29 10:37:30 PDT 2012
Make sure that the mask layer has polygons (features) in it, or if you are
editing, make sure that you've saved the polygons you drew.
(Asegúrate que la capa que usas como máscara tenga polígonos, o si estás
editandola, asegúrate que has guardado los polígonos que dibujaste).
Regards,
Germán
2012/8/29 lorena Coelho <lorena.r.coelho at gmail.com>
> Hola, probe  y no puedo...el error dice ERROR: Did not get any cutline
> features. La mascara si la crea...pero no me corta el raster. Muchas Gracias
> 2012/8/29 Germán Carrillo <carrillo.german at gmail.com>
>> Hi Lorena,
>> if you want to clip an image by using a mask layer, you must create first
>> that mask layer, which must be a polygon layer. You can do so in
>> Layer->New->New Shapefile Layer. Set for the mask layer the same reference
>> system of the image.
>> If you still have troubles please send to this list a detailed
>> description of the error you get, e.g., a screenshot or the error message.
>> I tried this out in QGIS 1.8.0 and it works.
>> Regards,
>> Germán
>> 2012/8/28 lorena Coelho <lorena.r.coelho at gmail.com>
>>> Hola, Muchas Gracias.
>>>  Voy a intentar explicarme. Estoy usando Quantum Gis 1.8.0 Lisboa. Para
>>> cortar un raster voy a RASTER/EXTRACCIÓN/CLIPPER. entonces se me abre un
>>> ventana que en el medio dice; Modo de corte y tengo dos opciones
>>> por extensión o por capa de mascara.
>>> Por extensión puedo cortar el raster sin problema pero..por capa de
>>> mascara no estoy pudiendo.
>>>  Lo cual no me esta permitiendo realizar cortes irregulares.
>>> Espero me puedan ayudar...Gracias
>>> 2012/8/28 Germán Carrillo <carrillo.german at gmail.com>
>>>> Or post your question in Spanish here, I know there is some people who
>>>> would understand, and  even if they are not able to solve your doubts, they
>>>> would help you rephrasing your question in English.
>>>> 2012/8/28 Etienne Tourigny <etourigny.dev at gmail.com>
>>>>> Hi I'm sorry but I don't understand your question... you mean that it
>>>>> doesn't work if the raster is a mask?
>>>>> By the way, there is a Spanish list at osgeo, although not specific to
>>>>> qgis
>>>>> http://lists.osgeo.org/pipermail/spanish/
>>>>> Etienne
>>>>> On Tue, Aug 28, 2012 at 3:39 PM, lorena Coelho
>>>>> <lorena.r.coelho at gmail.com> wrote:
>>>>> > Hi, thanks for your quick response. The add gdaltools what I have
>>>>> on. In
>>>>> > fact cut a raster if I can, so I can not cut the raster is a mask.
>>>>> That is
>>>>> > asking that the court limit is determined mask. Thanks. Lorena
>>>>> >> Believe it or not, names in 'Spanish' are:
>>>>> Ráster->Extraction->Clipper :)
>>>>> >> (Ráster->Extracción->Cortador/Cortar)
>>>>> >>> make sure gdaltools plugins is enabled (plugins->Manage Plugins),
>>>>> then
>>>>> >>> go to Raster->Extraction->clipper. Not sure what the names are in
>>>>> >>> español though.
>>>>> >>> On Tue, Aug 28, 2012 at 12:37 PM, lorena Coelho
>>>>> >>> > Hello,
>>>>> >>> > I am a magister student in Uruguay. I'm working with QGIS. I can
>>>>> not
>>>>> >>> > cut a
>>>>> >>> > raster mask,  can someone help. What is the complement need? I'm
>>>>> using
>>>>> >>> > Quantum GIS 1.8.0 Lisbon
>>>>> >>> > thanks
>>>>> >>> > _______________________________________________
>>>>> >>> > Qgis-user mailing list
>>>>> >>> > Qgis-user at lists.osgeo.org
>>>>> >>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> >>    |\__
>>>>> >> (:>__)(
>>>>> >> Soluciones Geoinformáticas Libres
>>>>> >> http://geotux.tuxfamily.org/
>>>>> >> http://twitter.com/GeoTux2
>>>>    |\__
>>>> (:>__)(
>>    |\__
>> (:>__)(
   |\__
(:>__)(
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120829/0d2221b8/attachment.html>
