[Qgis-user] QGIS Contour Generation
Zoltan Szecsei zoltans at geograph.co.za
Fri Aug 31 04:17:11 PDT 2012
Hi Federico,
Please email the list, and not the person directly.
The purpose of lists is to pool knowledge, not to give courses, so all
conversations relevant to the list should stay with the list.
Judging by your unfamiliarity with raster and vector data formats, it
seems like you need deeper knowledge about what you are doing, rather
than just assistance with the use of QGis.
I don't have any URLs I can suggest for this, but perhaps someone else
on this list can help.
Kind regards,
Zoltan
On 2012/08/31 12:29, Federico M Nadela wrote:
> Dear Zoltan,
> Many thanks for your prompt reply. I have not used shape file before
> so you have to walk me through. My DSM is in .tiff format. Can I use
> that instead of .shp?
> Please give me a sample of an acceptable output file. Thanks!
> Federico
> Sent from my iPhone
> On Aug 31, 2012, at 14:47, Zoltan Szecsei <zoltans at geograph.co.za
> <mailto:zoltans at geograph.co.za>> wrote:
>> On 2012/08/31 08:36, Federico Nadela wrote:
>>> I have reached as far as the Contour tab but unable to specify an
>>> acceptable output file path in the *Output file for contour
>>> lines(vector*). I tried to input _C:/User/Fritz/Documents/Temp.shp_
>>> but got an error message that says it is not a directory. I tried
>>> other paths but they were all unacceptable. Please advise. Thanks!
>>> Federico M. nadela
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Yep, true - if your 'Temp.shp' is not a DIRECTORY within your
>> documents folder.
>> What you and I call "shapefiles" is actually a group of 3 or more
>> files that are needed by ESRI and other GIS products that use
>> 'shapefile format'
>> For this reason you must specify the name of an existing directory,
>> and not a filename that you want to create.
>> Are you sure the "other paths" you tried existed and were actually
>> directory names?
>> HTH,
>> Zoltan
>> Zoltan Szecsei PrGISc [PGP0031]
>> Geograph (Pty) Ltd.
>> P.O. Box 7, Muizenberg 7950, South Africa.
>> 65 Main Road, Muizenberg 7945
>> Western Cape, South Africa.
>> 34° 6'16.35"S 18°28'5.62"E
>> Tel: +27-21-7884897  Mobile: +27-83-6004028
>> Fax: +27-86-6115323www.geograph.co.za
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
Geograph (Pty) Ltd.
Fax: +27-86-6115323     www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120831/fc7304a4/attachment.html>
