[Qgis-user] QGIS Contour Generation
Zoltan Szecsei zoltans at geograph.co.za
Thu Aug 30 23:47:16 PDT 2012
On 2012/08/31 08:36, Federico Nadela wrote:
> I have reached as far as the Contour tab but unable to specify an
> acceptable output file path in the *Output file for contour
> lines(vector*). I tried to input _C:/User/Fritz/Documents/Temp.shp_
> but got an error message that says it is not a directory. I tried
> other paths but they were all unacceptable. Please advise. Thanks!
> Federico M. nadela
> Qgis-user mailing list
Yep, true - if your 'Temp.shp' is not a DIRECTORY within your documents
folder.
What you and I call "shapefiles" is actually a group of 3 or more files
that are needed by ESRI and other GIS products that use 'shapefile format'
For this reason you must specify the name of an existing directory, and
not a filename that you want to create.
Are you sure the "other paths" you tried existed and were actually
directory names?
HTH,
Zoltan
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
P.O. Box 7, Muizenberg 7950, South Africa.
65 Main Road, Muizenberg 7945
Western Cape, South Africa.
34° 6'16.35"S 18°28'5.62"E
Tel: +27-21-7884897  Mobile: +27-83-6004028
Fax: +27-86-6115323     www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120831/16342181/attachment.html>
