[Qgis-user] Which path to R in Sextante plugin?
magerlin
MAP at ramboll.dk
Fri Aug 31 10:43:38 PDT 2012
I'm trying to make Sextante run some of the example plugins, but I get no
output (either Sextante displays "Could not load layer C:\...\*.shp" or I
get a result window just showing a question mark) and I get no error
messages.
Sextante nicely writes an R script in the file
C:\Users\map\sextante\sextante_script.r.
I can manually run this script i RGui and it works fine, but the script does
not appear to be run (correctly) from Sextante.
I am working on a Win 7 64 bit PC and I am a bit in doubt about which path
to add for R in Sextante Options?
In my R installation I have these two paths to R.exe:
C:\Program Files\R\R-2.15.1\bin\x64\R.exe
C:\Program Files\R\R-2.15.1\bin\R.exe
What path do I specify in Sextante? I have tried various alternatives but I
have had no luck.
Regards Morten
Qgis 1.8.0 Stand alone installer in Win7 64 bit
View this message in context: http://osgeo-org.1560.n6.nabble.com/Which-path-to-R-in-Sextante-plugin-tp4999100.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
