[Qgis-user] Which path to R in Sextante plugin?
G. Allegri giohappy at gmail.com
Fri Aug 31 10:45:41 PDT 2012
I confirm the same problem with Grass plugin, unable to load result
giovanni
Sent from Nexus
Il giorno 31/ago/2012 19:43, "magerlin" <MAP at ramboll.dk> ha scritto:
> I'm trying to make Sextante run some of the example plugins, but I get no
> output (either Sextante displays "Could not load layer C:\...\*.shp" or I
> get a result window just showing a question mark) and I get no error
> messages.
> Sextante nicely writes an R script in the file
> C:\Users\map\sextante\sextante_script.r.
> I can manually run this script i RGui and it works fine, but the script
> does
> not appear to be run (correctly) from Sextante.
> I am working on a Win 7 64 bit PC and I am a bit in doubt about which path
> to add for R in Sextante Options?
> In my R installation I have these two paths to R.exe:
> C:\Program Files\R\R-2.15.1\bin\x64\R.exe
> C:\Program Files\R\R-2.15.1\bin\R.exe
> What path do I specify in Sextante? I have tried various alternatives but I
> have had no luck.
> Regards Morten
> Qgis 1.8.0 Stand alone installer in Win7 64 bit
> http://osgeo-org.1560.n6.nabble.com/Which-path-to-R-in-Sextante-plugin-tp4999100.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120831/dc97670b/attachment.html>
