[Qgis-user] How to display WMS legend (getLegendGraphic-request) in QGIS
Astrid Emde astrid.emde at wheregroup.com
Tue Dec 11 23:54:04 PST 2012
Hello Diego,
thanks a lot for the enhancement of the plugin. I updated the plugin and
it works perfect with the https-WMS.
Best regards
Astrid Emde
Am 11.12.2012 18:08, schrieb Diego Mo:
> Hello Astrid
> if you can update the plugin from the same repository, it should now
> work also with WMS exposed via https (the one you reported it works
> for me)
> best regards
> Diego Mo
> CSI-Piemonte
> Direzione Territorio e Ambiente
>  >  _________________________________________________________________________
>  >  Il 10 dicembre 2012 alle 11.14 Astrid Emde
> <astrid.emde at wheregroup.com> ha scritto:
>> Hello Diego,
>>  >   we tested the new CSI WMS Legend plugin a bit more and noticed
>> that it does not support https-Requests for WMS.
>>  >   Is support for https-requests not implemented yet?
>>  >   Here is a demo WMS with an https-address.
>> https://lx-gis.stadt.wolfsburg.de/cgi-bin/mapserv?map=/gds/map/stadtteilgrenzen_extern.map&VERSION=1.1.1
>>  >   Best regards Astrid Emde
>>  >   Am 07.12.2012 14:17, schrieb Astrid Emde:
>>> Hello Diego,
>>>  >   thanks for the information. I tried the plugin and it is what I
>>> am looking for.
>>>  >   It shows the legend of the layer that has the focus in the
>>> layertree. Nice.
>>>  >   Thanks for your help.
>>>  >   Astrid
>>>  >   Am 07.12.2012 13:16, schrieb Diego Mo:
>>>> Recently we build a little QGIS plugin to display WMS legends.
>>>> It work with QGIS 1.8, not yet with the nightly build.
>>>>  >   We are going to release this plugin on the official repo.
>>>>  >   At the moment, if you want test it, you can download it from
>>>> this repo:
>>>> http://osgis.csi.it/qgis_plugin/csi_plugin_test.htm(remember to set
>>>> "Show all plugin, even those marked as experimental" in the python
>>>> plugin option panel)
>>>>  >   Thanks in advance for every feed back
>>>>  >   Best regards
>>>>  >   Diego Mo
>>>>  >   CSI-Piemonte
>>>>  >  Il 7 dicembre 2012 alle 9.28 Astrid Emde
>>>> <astrid.emde at wheregroup.com> <mailto:astrid.emde at wheregroup.com> ha
>>>> scritto:
>>>>  >  > Am 07.12.2012 09:12, schrieb Jürgen E. Fischer:
>>>>  >  > > Hi Astrid,
>>>>  >  > > On Fri, 07. Dec 2012 at 09:51:57 +0100, Astrid Emde wrote:
>>>>  >  > >> I am using WMS in QGIS and would like to diplay the legend
>>>> from the
>>>>  >  > >> getLegendGraphic-request in my application.
>>>>  >  > >> Is there a possibility to do this?
>>>>  >  > > I think there's no client support for that yet. The server
>>>> has support for
>>>>  >  > > that and the webclient uses it, but the legend for the WMS.
>>>>  >  > > We could probably replace the "standard" raster legend item
>>>> with the
>>>>  >  > > getlegendgraphcis response.
>>>>  >  > > Jürgen
>>>>  >  > Hello Jürgen,
>>>>  >  > thanks for your reply.
>>>>  >  > The Solution to use the getlegendgraphcis response if it
>>>> exists sounds
>>>>  >  > good to me. Maybe it could be displayed in a separate frame
>>>> in QGIS.
>>>>  >  > I am using QGIS 1.8-0
>>>>  >  > Mit freundlichen Grüßen
>>>>  >  > Astrid Emde
>>>>  >  > Where2B Konferenz 2012
>>>>  >  > 13. Dezember 2012 in Bonn
>>>>  >  > www.where2b-conference.com <http://www.where2b-conference.com>
>>>>  >  > Astrid Emde
>>>>  >  > WhereGroup GmbH & Co.KG
>>>>  >  > Eifelstraße 7
>>>>  >  > 53119 Bonn
>>>>  >  > Germany
>>>>  >  > Fon: +49(0)228 90 90 38 - 19
>>>>  >  > Fax: +49(0)228 90 90 38 - 11
>>>>  >  > astrid.emde at wheregroup.com <mailto:astrid.emde at wheregroup.com>
>>>>  >  > www.wheregroup.com <http://www.wheregroup.com>
>>>>  >  > Folgen Sie der WhereGroup auf twitter:
>>>> http://twitter.com/WhereGroup_com
>>>>  >  > Amtsgericht Bonn, HRA 6788
>>>>  >  > Komplementärin:
>>>>  >  > WhereGroup Verwaltungs GmbH
>>>>  >  > vertreten durch:
>>>>  >  > Olaf Knopp, Peter Stamm
>>>>  >  > pgp-public key:
>>>>  >  > http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>>>>  >  > Signierte und/oder verschlüsselte Nachrichten sind sehr
>>>> willkommen
>>>>  >  > Signed and/or encrypted mail is highly appreciated
>>>>  >  > Qgis-user mailing list
>>>>  >  > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>>  >  > http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Astrid Emde
>>>  Astrid Emde
>>>  Eifelstraße 7
>>>  53119 Bonn
>>>  Germany
>>>  Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
>>> Komplementärin:
>>> vertreten durch:
>>>  pgp-public key:
>>>   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>> Astrid Emde
>>  Astrid Emde
>>  Eifelstraße 7
>>  53119 Bonn
>>  Germany
>> Komplementärin:
>> vertreten durch:
>>  pgp-public key:
Astrid Emde
 Astrid Emde
 Eifelstraße 7
 53119 Bonn
 Germany
 www.wheregroup.com
Komplementärin:
vertreten durch:
 pgp-public key:
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121212/cc4d3b60/attachment.html>
