[Qgis-user] [qgisserver] relatif path in qgs and raster issue
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed Feb 1 06:44:14 PST 2012
Hi Yves
QGIS server in version 1.7.3 does not work (but will be ok in 1.7.4
again). Trunk is fine as well.
>I am testing qgis-server with libqgis-1.7.3 and qgis-1.7.1
Oh, are you mixing different library / application versions? Maybe the strange raster effects are because of that (I'm surprised it work at all).
And yes, relative paths are supported by QGIS server.
Regards,
Marco
On 01.02.2012 14:46, Yves Jacolin wrote:
> Hello,
> I am testing qgis-server with libqgis-1.7.3 and qgis-1.7.1 for the deskop
> side.
> I create a qgis project with qgis-1.7.1 all is fine. I have two layers : raster
> in netCDF and another in shapefile. I put this qgis project file to the server
> and test my new WMS service. The raster layer is rotated and reversed (see
> [1]).
> If I upgrade qgis on my desktop to 1.7.3 I get the same issue.
> Is it something known? I don't have the possibility to test the 1.7.4 release
> as the ubuntu package is not ready. I will try to investigate tonight as I
> have a trunk install for QGIS at home.
> Last question: relatif path could not be used in qgis project file for qgis-
> server. That seems curious to me as the path is not always the same between
> the deskop system and the server system. Anyway do you plan to change this? Do
> I need to fill a ticket?
> Thanks,
> Y.
> [1] http://imageshack.us/photo/my-images/15/qgisserver.png/
Dr. Marco Hugentobler
Sourcepole -  Linux&  Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
