[Qgis-user] [qgisserver] relatif path in qgs and raster issue
Yves Jacolin yjacolin at free.fr
Wed Feb 1 07:24:24 PST 2012
Marco,
Le mercredi 01 février 2012 15:44:14, Marco Hugentobler a écrit :
> Hi Yves
> QGIS server in version 1.7.3 does not work (but will be ok in 1.7.4
> again). Trunk is fine as well.
ok thanks, it helps me :) I have a solution now.
> >I am testing qgis-server with libqgis-1.7.3 and qgis-1.7.1
> Oh, are you mixing different library / application versions? Maybe the
> strange raster effects are because of that (I'm surprised it work at all).
not at all! I juste created a qgs file from my QGIS 1.7.1 and use it from qgis
server 1.7.3 then I tested this qgs file with QGIS 1.7.3 desktop (upgrade from
ubuntugis).
Thanks,
Y.
> And yes, relative paths are supported by QGIS server.
> Regards,
> Marco
> On 01.02.2012 14:46, Yves Jacolin wrote:
> > Hello,
> > I am testing qgis-server with libqgis-1.7.3 and qgis-1.7.1 for the deskop
> > side.
> > I create a qgis project with qgis-1.7.1 all is fine. I have two layers :
> > raster in netCDF and another in shapefile. I put this qgis project file
> > to the server and test my new WMS service. The raster layer is rotated
> > and reversed (see [1]).
> > If I upgrade qgis on my desktop to 1.7.3 I get the same issue.
> > Is it something known? I don't have the possibility to test the 1.7.4
> > release as the ubuntu package is not ready. I will try to investigate
> > tonight as I have a trunk install for QGIS at home.
> > Last question: relatif path could not be used in qgis project file for
> > qgis- server. That seems curious to me as the path is not always the
> > same between the deskop system and the server system. Anyway do you plan
> > to change this? Do I need to fill a ticket?
> > Thanks,
> > Y.
> > [1] http://imageshack.us/photo/my-images/15/qgisserver.png/
Yves Jacolin
http://yjacolin.gloobe.org
