[Qgis-user] Re: GPX and GPX_USE_EXTENSIONS
Luca Casagrande luca.casagrande at gmail.com
Mon Feb 27 08:10:24 PST 2012
Sorry Marco, but probably I am missing something.
What do you mean by "add to the source shapefile"? The source shapefile is a
line one, so I can't add points to it.
Thx
Luca
Marco Lechner - FOSSGIS e.V. wrote
> Adding it to the source shapefile and then converting?
> Am 27.02.2012 16:52, schrieb Luca Casagrande:
>> Yes, I used the Save As option.
>> Do you know any other way to add waypoints to an existing GPX file?
>> Luca
>>> Hi Luca,
>>> "converting" a Shape to GPX uses OGR-tools while the GPS-Plugin is a
>>> very long existing plugin reading/writing GPS natively, I guess.
>>> Marco
>>> Am 27.02.2012 16:40, schrieb Luca Casagrande:
>>>> Hello everybody,
>>>> I converted a line ShapeFile into GPX using the GPX_USE_EXTENSIONS
>>>> option
>>>> and the attributes are correctly exported.
>>>> Now, if I try to add some waypoints to that file using the GPS Plugin,
>>>> the
>>>> attributes disappear.
>>>> Anyone with the same problem?
>>>> Thanks
>>>> Luca
>>>> View this message in context:
>>>> http://osgeo-org.1560.n6.nabble.com/GPX-and-GPX-USE-EXTENSIONS-tp4515205p4515205.html
>>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at .osgeo
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Qgis-user at .osgeo
>> http://osgeo-org.1560.n6.nabble.com/GPX-and-GPX-USE-EXTENSIONS-tp4515205p4515243.html
>> Qgis-user at .osgeo
> Qgis-user at .osgeo
View this message in context: http://osgeo-org.1560.n6.nabble.com/GPX-and-GPX-USE-EXTENSIONS-tp4515205p4515286.html
