[Qgis-user] Re: GPX and GPX_USE_EXTENSIONS
Marco Lechner - FOSSGIS e.V. marco.lechner at fossgis.de
Mon Feb 27 08:41:09 PST 2012
if you need GPX_USE_EXTENSIONS create a point shape, digitize your
waypoints and convert it to GPX.
You easily can combine multiple GPX-files using an ordinary editor,
because it's as simple XML-dialect.
Marco
Am 27.02.2012 17:10, schrieb Luca Casagrande:
> Sorry Marco, but probably I am missing something.
> What do you mean by "add to the source shapefile"? The source shapefile is a
> line one, so I can't add points to it.
> Thx
> Luca
> Marco Lechner - FOSSGIS e.V. wrote
>> Adding it to the source shapefile and then converting?
>> Am 27.02.2012 16:52, schrieb Luca Casagrande:
>>> Yes, I used the Save As option.
>>> Do you know any other way to add waypoints to an existing GPX file?
>>> Luca
>>>> Hi Luca,
>>>> "converting" a Shape to GPX uses OGR-tools while the GPS-Plugin is a
>>>> very long existing plugin reading/writing GPS natively, I guess.
>>>> Marco
>>>> Am 27.02.2012 16:40, schrieb Luca Casagrande:
>>>>> Hello everybody,
>>>>> I converted a line ShapeFile into GPX using the GPX_USE_EXTENSIONS
>>>>> option
>>>>> and the attributes are correctly exported.
>>>>> Now, if I try to add some waypoints to that file using the GPS Plugin,
>>>>> the
>>>>> attributes disappear.
>>>>> Anyone with the same problem?
>>>>> Thanks
>>>>> Luca
>>>>> View this message in context:
>>>>> http://osgeo-org.1560.n6.nabble.com/GPX-and-GPX-USE-EXTENSIONS-tp4515205p4515205.html
>>>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at .osgeo
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Qgis-user at .osgeo
>>> http://osgeo-org.1560.n6.nabble.com/GPX-and-GPX-USE-EXTENSIONS-tp4515205p4515243.html
>>> Qgis-user at .osgeo
>> Qgis-user at .osgeo
> View this message in context: http://osgeo-org.1560.n6.nabble.com/GPX-and-GPX-USE-EXTENSIONS-tp4515205p4515286.html
