[Qgis-user] PyQgis MapServer Export with Mapserver 6.0.1
Siki Zoltan siki at agt.bme.hu
Mon Jan 30 12:52:03 PST 2012
Hello Francesc,
you should change the pathes.
   FONTSET './fonts/fonts.txt'
   SYMBOLSET './symbols/symbols.sym'
The fonts.txt and symbols.sym (or whatever filename) should be created if
neccessary. If you have point layer then you must create your own
symbolset, otherwise to can erase the SYMBOLSET line.
If you have trutype labels then you must create your fontset file,
otherwise you can erase the FONTSET line.
You must change
     IMAGEPATH '/C:/Users/Francesc/Documents/temp/'
to point to the document folder (or subfolder of that) of your web server.
In case of ms4w:
     IMAGEPATH 'C:/ms4w/Apache/htdocs/ms_tmp/'
IMAGEURL is the path from the Apache's document folder:
     IMAGEURL '/ms_tmp/'
If you move your vector or raster files you must change the DATA for the
layer. This case you had better to set up SHAPEPATH in your map file.
Regards
Zoltan
On Mon, 30 Jan 2012, Francesc Caas wrote:
> Hi,
> I've created a map file with the PyQgis Mapserver export pluggin but it
> doesn't work. They tell me it's cause the plugguin it's for older versions
> of mapserver. (I have the 6.0.1)
> What changes I have to do in the .map file to makes it work?
> Thanks!
> Map code:
> # Map file created from QGIS project file
> C:/Users/Francesc/Documents/Projectes_CAT_wgs.qgs
> # Edit this file to customize for your map interface
> # (Created with PyQgis MapServer Export plugin)
> MAP
>  NAME "Projectes Auma UTM31"
>  # Map image size
>  SIZE 100 100
>  UNITS dd
>  EXTENT -9.569062 32.926808 6.763360 44.857479
>  PROJECTION
>    'proj=longlat'
>    'datum=WGS84'
>    'no_defs'
>  END
>  # Background color for the map canvas -- change as desired
>  IMAGECOLOR 255 255 255
>  IMAGEQUALITY 95
>  IMAGETYPE png
>  OUTPUTFORMAT
>    NAME png
>    DRIVER 'GD/PNG'
>    MIMETYPE 'image/png'
>    IMAGEMODE RGBA
>    EXTENSION 'png'
>  END
>  # Legend
>  LEGEND
>    STATUS ON
>    KEYSIZE 18 12
>    LABEL
>      TYPE BITMAP
>      SIZE MEDIUM
>      COLOR 0 0 89
>    END
>  END
>  # Web interface definition. Only the template parameter
>  # is required to display a map. See MapServer documentation
>  WEB
>    # Set IMAGEPATH to the path where MapServer should
>    # write its output.
>    IMAGEPATH 'C:/Users/Francesc/Documents/temp/'
>    # Set IMAGEURL to the url that points to IMAGEPATH
>    # as defined in your web server configuration
>    IMAGEURL '/C:/Users/Francesc/Documents/temp/'
>    # WMS server settings
>    METADATA
>      'ows_title'           'Projectes Auma UTM31'
>      'ows_onlineresource'
> 'http://localhost/cgi-bin/mapserv.exe?map=C:/Users/Francesc/Documents/Projectes_wgs84_v7.map'
>      'ows_srs'             'EPSG:4326'
>    END
>    #Scale range at which web interface will operate
>    # Template and header/footer settings
>    # Only the template parameter is required to display a map. See
>    TEMPLATE 'fooOnlyForWMSGetFeatureInfo'
>  END
>  LAYER
>    NAME 'Provincias_wgs84'
>    TYPE POLYGON
>    DUMP true
>    TEMPLATE fooOnlyForWMSGetFeatureInfo
>    DATA 'C:/Users/Francesc/Documents/SHP/Provincias_wgs84.shp'
>    METADATA
>      'ows_title' 'Provincias_wgs84'
>    END
>    STATUS OFF
>    TRANSPARENCY 100
>    PROJECTION
>    'proj=longlat'
>    'datum=WGS84'
>    'no_defs'
>    END
>    CLASS
>       STYLE
>         WIDTH 0.35
>         OUTLINECOLOR 0 0 0
>       END
>    END
>  END
>  LAYER
>    NAME 'Projectes_UTM31_wgs84'
>    TYPE POINT
>    DUMP true
>    DATA 'C:/Users/Francesc/Documents/SHP/Projectes_UTM31_wgs84.shp'
>    METADATA
>      'ows_title' 'Projectes_UTM31_wgs84'
>    END
>    STATUS OFF
>    TRANSPARENCY 100
>    PROJECTION
>    'proj=longlat'
>    'datum=WGS84'
>    'no_defs'
>    END
>    CLASS
>       STYLE
>         SYMBOL "circle"
>         SIZE 7.0
>         OUTLINECOLOR 0 0 0
>         COLOR 103 132 169
>       END
>    END
>  END
> END
> View this message in context: http://osgeo-org.1560.n6.nabble.com/PyQgis-MapServer-Export-with-Mapserver-6-0-1-tp4350528p4350528.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
