[Qgis-user] Re: PyQgis MapServer Export with Mapserver 6.0.1
Francesc CaƱas
kikocanas at gmail.com
Tue Jan 31 00:47:08 PST 2012
I've maked all the changes that you say and others that I found:
My first error was cause the type cartoline for symbols is no longer used. I
erased all in my symbol file.
The GD driver is no longer used for PNG output. So I've removed all the
OUTPUTFORMAT blog.
I've put a SHAPEPATH, I've erased the FONTSET but not the Symbolset cause I
have a point shape.
I've changed IMAGEPATH 'C:/ms4w/Apache/htdocs/ms_tmp/'
and IMAGEURL '/ms_tmp/'
I have all the folders and all data in C:/ms4w/Apache/htdocs/
Now, the message error is:
*Content-type: text/html msReturnPage(): Web application error. Malformed
template name (fooOnlyForWMSGetFeatureInfo).*
And the code at time is:
# Map file created from QGIS project file
C:/Users/Francesc/Documents/Projectes_CAT_wgs.qgs
# Edit this file to customize for your map interface
# (Created with PyQgis MapServer Export plugin)
MAP
NAME "Projectes Auma UTM31"
# Map image size
SIZE 100 100
UNITS dd
EXTENT -9.569062 32.926808 6.763360 44.857479
SYMBOLSET './symbols/symbols.sym'
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
SHAPEPATH 'C:/ms4w/Apache/htdocs/SHP/'
# Background color for the map canvas -- change as desired
IMAGECOLOR 255 255 255
IMAGEQUALITY 100
IMAGETYPE png
# Legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL '/ms_tmp/'
# WMS server settings
METADATA
'ows_title' 'Projectes Auma UTM31'
'ows_onlineresource'
'http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/Projectes_wgs84_v7.map'
'ows_srs' 'EPSG:4326'
END
#Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See
TEMPLATE 'fooOnlyForWMSGetFeatureInfo'
END
LAYER
NAME 'Provincias_wgs84'
TYPE POLYGON
DUMP true
TEMPLATE fooOnlyForWMSGetFeatureInfo
DATA '/SHP/Provincias_wgs84.shp'
METADATA
'ows_title' 'Provincias_wgs84'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASS
STYLE
WIDTH 0.35
OUTLINECOLOR 0 0 0
END
END
END
LAYER
NAME 'Projectes_UTM31_wgs84'
TYPE POINT
DUMP true
DATA '/SHP/Projectes_UTM31_wgs84.shp'
METADATA
'ows_title' 'Projectes_UTM31_wgs84'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASS
STYLE
SYMBOL "circle"
SIZE 7.0
OUTLINECOLOR 0 0 0
COLOR 103 132 169
END
END
END
END
Thanks a lot!
View this message in context: http://osgeo-org.1560.n6.nabble.com/PyQgis-MapServer-Export-with-Mapserver-6-0-1-tp4350528p4352838.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
