[Qgis-user] DXF EXPORT
Zirneklitis eko at lanet.lv
Sun Jul 1 08:31:33 PDT 2012
You should manually fix extent. You have to look for strings $EXTMIN and
$EXTMAX and correct the actual extent values Xmin, Ymin, Zmin, Xmax,
Ymax, Zmax. I soppose Zmin and Zmax are "0" (without quotes).
$EXTMIN
10 Xmin
20 Ymin
30 Zmin
9
$EXTMAX
10 Xmax
20 Ymax
30 Zmax
9
Karlis
Bis Nulama wrote:
> Autocad says:
> The database manager is not valid: 0 to the line 1548.
> Invalid or incomplete DXF input - drawing deleted.
> Then it crashes
> I tried to delete line 1548 but it doesn't work
> I tried to open the dxf file with Inkscape, I do not get errors but it
> seems to be empty...
