[Qgis-user] Start up error Grass related
Radim Blazek radim.blazek at gmail.com
Mon Jul 2 23:54:48 PDT 2012
On Sun, Jul 1, 2012 at 4:18 PM, virgo1066 <mrmelton at cox.net> wrote:
> When I run QGIS 1.7.4 on my laptop I receive the following splash screen:
> "QGIS couldn't find your Grass installation. Would you like to specify path
> (GISBASE) to your GRASS installation?"
GISBASE is path to a directory where GRASS is installed. Where is your
GRASS installed?
> I have tried various solutions, however no joy as yet.
If you get the message above, you are then asked to select the path to
GRASS in dialog, right? You select the path to dir where GRASS is
installed and it does not work?
Radim
> Running Win7-64 bit
> QGIS runs fine on my desktop also running Win7-64 bit
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Start-up-error-Grass-related-tp4985164.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
