[Qgis-user] contour plugin
Alex Mandel tech_dev at wildintellect.com
Sun Jul 8 12:40:53 PDT 2012
On 07/08/2012 12:36 PM, john raskulinecz wrote:
> Hello Giovani,Thank you for your suggestion but I guess my problem is finding the plugin. When I go to manage plugins and try to add  I don't see contour as an option. It shows add delimited text layer, co-ordinate capture, etc. all of which I have and use but, alas no contour.It seems that after I used to add the delim txt layers I could right click on poperties and contour the chosen attibutes by chosen incremental values. Is there a plugin repository other than Pythonthat holds the contour tool?again, thanks.J.R.
Since you're using 1.7.4, in Fetch Python Plugins look for the Add 3rd
Party repos. Once thats loaded you should be able to find the Contour
plugin.
Alex
