[Qgis-user] contour plugin
Vittorio Dell'Aquila viorayli at gmail.com
Mon Jul 9 06:36:39 PDT 2012
Thank you for your quick answer.
Actually matplotlib is installed (on MacOs Lion Server) and with QGis 1.8 I
see that there is the same error as with QGis 1.7: it has something to do
with matplotlib and not with QGis. It was a known bug, but I could not find
(even when I have installed QGIs 1.7) any feasable solution to correct the
problem.
vd
2012/7/9 Giovanni Manghi <giovanni.manghi at faunalia.pt>
> > ImportError: No module named matplotlib
> the message is clear, you misses matplotlib, that is easily installable
> with osgeo4w or with your favourite package manager if you use Linux.
> cheers
> -- Giovanni --
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120709/13dad0df/attachment.html>
