[Qgis-user] Contour plugin
José Carlos Guerrero Antúnez jcgantunez at gmail.com
Tue Jul 10 13:06:39 PDT 2012
I followed the procedure outlined on the web (
http://pypi.python.org/pypi/Shapely/) from Installation section
torre-a-102:~ joseca_IMac$ easy_install libgeos_c
Searching for libgeos-c
Reading http://pypi.python.org/simple/libgeos_c/
Reading http://pypi.python.org/simple/libgeos-c/
Couldn't find index page for 'libgeos_c' (maybe misspelled?)
Scanning index of all packages (this may take a while)
No local packages or download links found for libgeos-c
error: Could not find suitable distribution for
Requirement.parse('libgeos-c')
torre-a-102:~ joseca_IMac$            $ pip install Shapely
-bash:                                          $: command not found
torre-a-102:~ joseca_IMac$           $ python setup.py install
I don't know how to solve this problem?
Regards,
Jose C. Guerrero
2012/7/8 Noli Sicad <nsicad at gmail.com>
> Install Shapely first.
> Noli
> On Sunday, July 8, 2012, José Carlos Guerrero Antúnez wrote:
>> Hi,
>> I want to install Contour plugin but I have the following error message:
>> "The plugin depends on some components missing you on your system. You
>> need to install the following Python module in order to enable it:
>> shapely.geometry"
>> I work with 1.8 Lisboa
>> MacOSX 10.6.8.
>> Any hint? How do I install the plugin?
>> Best regards
>> Jose C. Guerrero
>> Dr. José Carlos Guerrero
>> Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio
>> (LDSGAT)
>> Instituto de Ecología y Ciencias Ambientales (IECA)
>> Facultad de Ciencias
>> Universidad de la República
>> Montevideo-URUGUAY
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120710/aa901956/attachment.html>
