[Qgis-user] plugin help
Nathan Woodrow madmanwoo at gmail.com
Thu Jul 12 05:57:39 PDT 2012
:S difficult?
layer.startEditing()
layer.commitChanges()
On Thu, Jul 12, 2012 at 10:54 PM, chathura silva <chathurait at gmail.com> wrote:
> hey Its difficult . Is there any simple way to change to edit mode
> On Thu, Jul 12, 2012 at 5:41 AM, Richard Duivenvoorde <rdmailings at duif.net>
> wrote:
>> Hi,
>> ok, this is more clear :-)
>> You can toggle editing mode of a vector layer via the little crayon button
>> or via menu layer/toggle editing
>> but looking into the code, which I downloaded from
>> http://pyqgis.org/repo/contributed/
>> it seems to me that after every transformation, the result is 'commited'
>> which toggles OFF again the edit mode...
>> If you feel brave, uncomment line 118 in qgsAffine.py:
>>     # vlayer.commitChanges()
>> But maybe Mauricio can update the code for us, and also move his plugin to
>> the new repositiry :-)
>> Regards,
>> Richard
>> ps I will send you my .py file offline
>> On 07/12/2012 12:25 PM, chathura silva wrote:
>>> I try to edit a vector layer using qgisaffine tool. But it says layer is
>>> not in editabale mode. how can I cange it to editable mode
>>> On Thu, Jul 12, 2012 at 1:27 AM, Richard Duivenvoorde
>>> <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
>>>     On 07/12/2012 09:16 AM, chathura silva wrote:
>>>         Is there any way to change it to editable mode ?
>>>     Please describe your problem a little more instead of one sentence
>>>     questions, for others it also costs time to answer your question.
>>>     If you mean 'is it possible for a python plugin to set a layer in
>>>     the modus editing' the answer is:
>>>     yes
>>>     but I think you also would like to see some pointers (after you
>>>     tried to google a little ;-) ):
>>>     Have a look here:
>>> http://qgis.org/pyqgis-__cookbook/vector.html#__modifying-vector-layers
>>>     <http://qgis.org/pyqgis-cookbook/vector.html#modifying-vector-layers>
>>>     I'm also setting a layer into editing mode, see
>>> http://hub.qgis.org/projects/__xytools/repository/revisions/__a249004832f44334f9861483ff9d4d__a08bb91e81/entry/xytools.py
>>> <http://hub.qgis.org/projects/xytools/repository/revisions/a249004832f44334f9861483ff9d4da08bb91e81/entry/xytools.py>
>>>     at line 334
>>>     Regards,
>>>     _________________________________________________
>>>     Qgis-user mailing list
>>>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>     http://lists.osgeo.org/__mailman/listinfo/qgis-user
>>>     <http://lists.osgeo.org/mailman/listinfo/qgis-user>
