[Qgis-user] plugin help
Nathan Woodrow madmanwoo at gmail.com
Thu Jul 12 05:58:37 PDT 2012
and if you want to enabled editing for a layer in the UI.  Right-click
Layer in Legend -> Enabled Editing...
On Thu, Jul 12, 2012 at 10:57 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> :S difficult?
> layer.startEditing()
> layer.commitChanges()
> On Thu, Jul 12, 2012 at 10:54 PM, chathura silva <chathurait at gmail.com> wrote:
>> hey Its difficult . Is there any simple way to change to edit mode
>> On Thu, Jul 12, 2012 at 5:41 AM, Richard Duivenvoorde <rdmailings at duif.net>
>> wrote:
>>> Hi,
>>> ok, this is more clear :-)
>>> You can toggle editing mode of a vector layer via the little crayon button
>>> or via menu layer/toggle editing
>>> but looking into the code, which I downloaded from
>>> http://pyqgis.org/repo/contributed/
>>> it seems to me that after every transformation, the result is 'commited'
>>> which toggles OFF again the edit mode...
>>> If you feel brave, uncomment line 118 in qgsAffine.py:
>>>     # vlayer.commitChanges()
>>> But maybe Mauricio can update the code for us, and also move his plugin to
>>> the new repositiry :-)
>>> Regards,
>>> Richard
>>> ps I will send you my .py file offline
>>> On 07/12/2012 12:25 PM, chathura silva wrote:
>>>> I try to edit a vector layer using qgisaffine tool. But it says layer is
>>>> not in editabale mode. how can I cange it to editable mode
>>>> On Thu, Jul 12, 2012 at 1:27 AM, Richard Duivenvoorde
>>>> <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
>>>>     On 07/12/2012 09:16 AM, chathura silva wrote:
>>>>         Is there any way to change it to editable mode ?
>>>>     Please describe your problem a little more instead of one sentence
>>>>     questions, for others it also costs time to answer your question.
>>>>     If you mean 'is it possible for a python plugin to set a layer in
>>>>     the modus editing' the answer is:
>>>>     yes
>>>>     but I think you also would like to see some pointers (after you
>>>>     tried to google a little ;-) ):
>>>>     Have a look here:
>>>> http://qgis.org/pyqgis-__cookbook/vector.html#__modifying-vector-layers
>>>>     <http://qgis.org/pyqgis-cookbook/vector.html#modifying-vector-layers>
>>>>     I'm also setting a layer into editing mode, see
>>>> http://hub.qgis.org/projects/__xytools/repository/revisions/__a249004832f44334f9861483ff9d4d__a08bb91e81/entry/xytools.py
>>>> <http://hub.qgis.org/projects/xytools/repository/revisions/a249004832f44334f9861483ff9d4da08bb91e81/entry/xytools.py>
>>>>     at line 334
>>>>     Regards,
>>>>     _________________________________________________
>>>>     Qgis-user mailing list
>>>>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>>     http://lists.osgeo.org/__mailman/listinfo/qgis-user
>>>>     <http://lists.osgeo.org/mailman/listinfo/qgis-user>
