[Qgis-user] plugin help
Mauricio de Paulo mauricio.dev at gmail.com
Thu Jul 12 12:00:08 PDT 2012
Hi, thanks for the suggestion, Richard.
I accepted the change suggested and moved the plugin into the new
metadata system and repository.
I hope that in the following weeks we can already download it. When the
project gets approved, I'll start the git repository that should make
the contribution process more fluid.
All the best,
Mauricio de Paulo
On 07/12/2012 09:41 AM, Richard Duivenvoorde wrote:
> Hi,
> ok, this is more clear :-)
> You can toggle editing mode of a vector layer via the little crayon
> button or via menu layer/toggle editing
> but looking into the code, which I downloaded from
> http://pyqgis.org/repo/contributed/
> it seems to me that after every transformation, the result is
> 'commited' which toggles OFF again the edit mode...
> If you feel brave, uncomment line 118 in qgsAffine.py:
>     # vlayer.commitChanges()
> But maybe Mauricio can update the code for us, and also move his
> plugin to the new repositiry :-)
> Regards,
> Richard
> ps I will send you my .py file offline
> On 07/12/2012 12:25 PM, chathura silva wrote:
>> I try to edit a vector layer using qgisaffine tool. But it says layer is
>> not in editabale mode. how can I cange it to editable mode
>> On Thu, Jul 12, 2012 at 1:27 AM, Richard Duivenvoorde
>> <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
>>     On 07/12/2012 09:16 AM, chathura silva wrote:
>>         Is there any way to change it to editable mode ?
>>     Please describe your problem a little more instead of one sentence
>>     questions, for others it also costs time to answer your question.
>>     If you mean 'is it possible for a python plugin to set a layer in
>>     the modus editing' the answer is:
>>     yes
>>     but I think you also would like to see some pointers (after you
>>     tried to google a little ;-) ):
>>     Have a look here:
>> http://qgis.org/pyqgis-__cookbook/vector.html#__modifying-vector-layers
>> <http://qgis.org/pyqgis-cookbook/vector.html#modifying-vector-layers>
>>     I'm also setting a layer into editing mode, see
>> http://hub.qgis.org/projects/__xytools/repository/revisions/__a249004832f44334f9861483ff9d4d__a08bb91e81/entry/xytools.py
>> <http://hub.qgis.org/projects/xytools/repository/revisions/a249004832f44334f9861483ff9d4da08bb91e81/entry/xytools.py>
>>     at line 334
>>     Regards,
>>     _________________________________________________
>>     Qgis-user mailing list
>>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>     http://lists.osgeo.org/__mailman/listinfo/qgis-user
>> <http://lists.osgeo.org/mailman/listinfo/qgis-user>
