[Qgis-user] shp a GPS
Lene Fischer lfi at life.ku.dk
Mon Jul 16 00:48:34 PDT 2012
Hi JC
If I use GPSBabel I can´t find SHP format to convert. Which format do you use for uploading a SHP til GPS via Babel?
I normally use QGIS >Save As> GPX> GPX_USE_EXTENSIONS=yes
Then GPS-Tools>Upload to GPS
or  Save As and then choosing the GPS-disk (depending on which GPS I use)
Regards
Lene Fischer
________________________________________
Fra: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] på vegne af JC Notter [jc.notter at orange.fr]
Sendt: 16. juli 2012 09:21
Til: qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] shp a GPS
A good solution is to use GPSBAbel , 3 ways :
* command line
* GUI
* GPS tools plugin in Qgis (=> path to declare)
It makes a GPX file "compatible" for GPS
JC Notter
Le 15/07/2012 20:59, Juan Pablo Virgillito a écrit :
> Que tal, estoy tratando de cargar una ruta al GPS Garmin Etrex Legend,
> supuestamente haciendo click sobre el shape y gurdando como GPX
> estaría solucionado pero me da el siguiente error:
> Falló la exportación a archivo vectorial.
> Error: falló la creación del campo Name (error de OGR: Field of name
> 'Name' is not supported in GPX schema. Use GPX_USE_EXTENSIONS creation
> option to allow use of the <extensions> element.)
> Qgis-user mailing list
