[Qgis-user] shp a GPS
Andre Joost andre+joost at nurfuerspam.de
Mon Jul 16 02:03:55 PDT 2012
Am 16.07.12 09:48, schrieb Lene Fischer:
> Hi JC
> If I use GPSBabel I can´t find SHP format to convert. Which format do you use for uploading a SHP til GPS via Babel?
> I normally use QGIS>Save As>  GPX>  GPX_USE_EXTENSIONS=yes
> Then GPS-Tools>Upload to GPS
> or  Save As and then choosing the GPS-disk (depending on which GPS I use)
Save As > GPX only creates *routes* in GPX files. If you want *tracks*
instead, you can transform the file with GPSbabel using the filter option
routes -> tracks.
Or is there another way to get track-GPX directly out of Qgis?
I'm missing that feature in the GPS Tools.
Greetings,
André Joost
