[Qgis-user] shp a GPS
JC Notter jc.notter at orange.fr
Mon Jul 16 02:38:38 PDT 2012
Example if you use command to get a "good" GPX format :
wpt :
"C:\Program Files\GPSBabel\gpsbabel.exe" -i shape -f in.shp -x
transform,wpt=rte,del -o gpx -F out.gpx
trk :
transform,trk=rte,del -o gpx -F out.gpx
=> in.shp must be in wgs84 !
Regards
JC Notter
Le 16/07/2012 11:48, Lene Fischer a écrit :
> Hi JC
> If I use GPSBabel I can´t find SHP format to convert. Which format do you use for uploading a SHP til GPS via Babel?
> I normally use QGIS >Save As> GPX> GPX_USE_EXTENSIONS=yes
> Then GPS-Tools>Upload to GPS
> or  Save As and then choosing the GPS-disk (depending on which GPS I use)
> Regards
> Lene Fischer
> ________________________________________
> Fra: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] på vegne af JC Notter [jc.notter at orange.fr]
> Sendt: 16. juli 2012 09:21
> Til: qgis-user at lists.osgeo.org
> Emne: Re: [Qgis-user] shp a GPS
> Hi,
> A good solution is to use GPSBAbel , 3 ways :
> * command line
> * GUI
> * GPS tools plugin in Qgis (=> path to declare)
> It makes a GPX file "compatible" for GPS
> JC Notter
> Le 15/07/2012 20:59, Juan Pablo Virgillito a écrit :
>> Que tal, estoy tratando de cargar una ruta al GPS Garmin Etrex Legend,
>> supuestamente haciendo click sobre el shape y gurdando como GPX
>> estaría solucionado pero me da el siguiente error:
>> Falló la exportación a archivo vectorial.
>> Error: falló la creación del campo Name (error de OGR: Field of name
>> 'Name' is not supported in GPX schema. Use GPX_USE_EXTENSIONS creation
>> option to allow use of the <extensions> element.)
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Jean-Cyrille Notter
http://sig974.free.fr
http://vavangavelo.free.fr
