[Qgis-user] Qgiserver : "webserver configuration" error message(windows7)
Andreas Neumann a.neumann at carto.net
Mon Jul 16 03:07:32 PDT 2012
 Do you have a proxy in your LAN? If not, you can select "Direct
 Connection". If you have a proxy you can use either of the other two
 options. If IE works fine, you should probably select the IE option.
 Andreas
 On Sun, 15 Jul 2012 13:35:06 -0700 (PDT), laurent celati wrote:
> Hello,
> .I want install and test Qgis server on Windows7_64bits. I read the
> Qgis
> server tutorial available at :
> http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial
> I downloaded the OsGeo4w-Installer. I have tried to select settings
> proposed
> in the tutorial.
>  The tutorial says : "-> choose web-access due to your lan"
> At this step, i have choice beteween 3  connection types :
> * Direct Connection
> *Use IE5 Settings
> *Use HTTP/FTP Proxy
> Shall i select  the "Use HTTP/FTP Proxy" ? I selected it.I have
> briefed the
> field Proxy Host by tapping the IP of my computer (host) + Default
> Port
> (80).  But i have an error message saying :
> "Unable to get setup .ini from < http://download.osgeo.org/osgeo4w>
> Why i have got this error message?Is it obliged to use "Use HTTP/FTP
> Proxy"
> connection type ? Or i can select "Direct Connection" or "Use IE5
> Settings"?
> Thanks to throw light for me.
> Regards.
> http://osgeo-org.1560.n6.nabble.com/Qgiserver-webserver-configuration-error-message-windows7-tp4988455.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
