[Qgis-user] Qgiserver : "webserver configuration" error message(windows7)
Edwin Liava'a liavaa.edwin at gmail.com
Tue Jul 17 17:23:20 PDT 2012
Yes,
If you have a proxy, then use designated IP of proxy server with
designated port number, else just use direct connection.
cheers,
Edwin
On 7/16/2012 3:07 AM, Andreas Neumann wrote:
> Hi,
> Do you have a proxy in your LAN? If not, you can select "Direct
> Connection". If you have a proxy you can use either of the other two
> options. If IE works fine, you should probably select the IE option.
> Andreas
> On Sun, 15 Jul 2012 13:35:06 -0700 (PDT), laurent celati wrote:
>> Hello,
>> .I want install and test Qgis server on Windows7_64bits. I read the Qgis
>> server tutorial available at :
>> http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial
>> I downloaded the OsGeo4w-Installer. I have tried to select settings
>> proposed
>> in the tutorial.
>>  The tutorial says : "-> choose web-access due to your lan"
>> At this step, i have choice beteween 3  connection types :
>> * Direct Connection
>> *Use IE5 Settings
>> *Use HTTP/FTP Proxy
>> Shall i select  the "Use HTTP/FTP Proxy" ? I selected it.I have
>> briefed the
>> field Proxy Host by tapping the IP of my computer (host) + Default Port
>> (80).  But i have an error message saying :
>> "Unable to get setup .ini from < http://download.osgeo.org/osgeo4w>
>> Why i have got this error message?Is it obliged to use "Use HTTP/FTP
>> Proxy"
>> connection type ? Or i can select "Direct Connection" or "Use IE5
>> Settings"?
>> Thanks to throw light for me.
>> Regards.
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/Qgiserver-webserver-configuration-error-message-windows7-tp4988455.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
