[Qgis-user] Is it possibel to set composer grid label units to km instead of meters?
Ramon AndiƱach custard at westnet.com.au
Wed Jul 18 17:32:38 PDT 2012
Absolutely!
Just underneath where you told the Print Composer to use 1000 for the Segment size (map units) is a box labeled "Map units per bar unit". Have a play with that.
A bit further down is a box for "Unit label" which is also useful.
-ramon.
On 19/07/2012, at 06:58 , Alexandre Neto wrote:
> Hello all,
> Is it possible to set the composer Grid Labels units to Km?
> I'm using a 1000m x 1000m grid in the composer, the labels are in meter, I would like them to be in Km so I could eliminate a few Zeros.
> Thanks,
> Alexandre Neto
> Qgis-user mailing list
