[Qgis-user] Is it possibel to set composer grid label units to km instead of meters?
Giovanni Manghi giovanni.manghi at faunalia.pt
Thu Jul 19 01:18:46 PDT 2012
On Thu, 2012-07-19 at 08:32 +0800, Ramon AndiƱach wrote:
> Absolutely!
> Just underneath where you told the Print Composer to use 1000 for the Segment size (map units) is a box labeled "Map units per bar unit". Have a play with that.
> A bit further down is a box for "Unit label" which is also useful.
I guess that the question was about the grid (specifically annotations)
of the map object. If so then it doesn't seems to me that there is a an
option like "Map units per bar unit" as in the scalebar.
cheers
-- Giovanni --
