[Qgis-user] Is there a limit of loaded files in QGis 1.8 ?
Germán Carrillo carrillo.german at gmail.com
Thu Jul 19 02:37:48 PDT 2012
For those who want to try things out, in a Unix shell type:
lsof -p 10371
where 10371 is the QGIS process id (so, adjust it).
Each time you open a file, enter the same command and you'll see how many
files QGIS is opening.
Regards,
Germán
2012/7/19 maning sambale <emmanuel.sambale at gmail.com>
> would loading the shapefile as zip help?
> On Jul 19, 2012 4:10 PM, "Giovanni Manghi" <giovanni.manghi at faunalia.pt>
> wrote:
>> On Thu, 2012-07-19 at 09:15 +0200, Germán Carrillo wrote:
>> > Hi,
>> > indeed, it is an operating system (OS) restriction. In my GNU/Linux
>> > the limit is 1024 by default, but you are able to change it. You would
>> > need to search how to change it on your OS. See [1].
>> yes, it is a OS limit and remember also that when opening a shapefile
>> you are opening at least 3 files...
>> cheers
>> -- Giovanni --
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
   |\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
http://twitter.com/GeoTux2
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120719/7e923a74/attachment.html>
