[Qgis-user] Convert spreadsheet (excel) to vector (shape) of Points
Juan M. Bernales jm_bernales at hotmail.com
Mon Jul 23 18:28:06 PDT 2012
Hola puedes usar el plugin XYtools y ahi te da la opcion de importar como puntos, solo que lo tienes que tener en el formato de 97-2003, o puedes guardar los datos a un archivo *.CSV (en excel tienes esa opcion) y usar el plugin de "Añadir Capa de Texto Delimitado"
SALUDOS
JUAN M. BERNALES
Date: Mon, 23 Jul 2012 17:04:30 -0500
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Convert spreadsheet (excel) to vector (shape) of Points
Hello I'm Eduardo from Peru qgis initial user:excuse the bad English I'm using the google translator.I have a file format spreadsheet in which I have weather information of the fields (columns) of this file are the geographical coordinates of the stations (latitude, longitude and altitude) in degrees, minutes and seconds eg 21 º 23 '12' '
What I do is convert this file into a vector (shape) of points.what procedure I should follow.Thank you very much.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120723/64c8a563/attachment.html>
