[Qgis-user] [Qgis-developer] Fwd: qgis 1.8 on MAC: Problem with qwt and more
Agustin Lobo alobolistas at gmail.com
Tue Jul 24 14:27:28 PDT 2012
Yes, actually this is why I thought it had been included as core in 1.8.
But meanwhile, having a plugin is a very good solution. Also, we can
use the plugin as a testbed  and discuss
different improvements, like customizing the axes.
The table is not enough, you need a graph as soon as you have more
than 3 numbers...
Agus
2012/7/23 Werner Macho <werner.macho at gmail.com>:
> IMHO this tool is worth to be integrated as a core plugin. But I know
> that means a lot of work porting it to cpp.
> I know a lot of things I would like to see integrated in ValueTool too
> but I can only have some wishes as I am not able to do it myself ..
> kind regards
> Werner
> On Mon, Jul 23, 2012 at 3:47 PM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
>> Would it be best as a standalone, with qwt, or python with matplotlib?
>> Easiest short-term would be to port the plotting to matplotlib.
>> Also, is the raster interface going to change enough to break this plugin?
>> Regards,
>> Etienne
>> On Mon, Jul 23, 2012 at 10:16 AM, Giovanni Manghi
>> <giovanni.manghi at gmail.com> wrote:
>>> On Sun, 2012-07-22 at 10:01 -0300, Etienne Tourigny wrote:
>>>> Is the value tool pluin popular enough to be included either as
>>>> - a builtin plugin - using matplotlib instead of pyqt
>>>> -part of the main app - in c++ and qwt, which does not cause problems anywhere
>>> I would say "yes", this plugin is pretty much fundamental when doing
>>> some kind of raster analysis with QGIS/GRASS.
>>> cheers
>>> -- Giovanni --
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
