[Qgis-user] [Qgis-developer] Fwd: qgis 1.8 on MAC: Problem with qwt and more
Agustin Lobo alobolistas at gmail.com
Wed Jul 25 06:23:21 PDT 2012
Etienne suggested this problem could be caused by an old version of matplotlib.
On ubuntu 10.04, the newest is python-matplotlib 0.99.1.2.
I solved the problem by:
1. uninstalling python-matplotlib 0.99.1.2. (et. al) using synaptic
2. Visiting http://matplotlib.sourceforge.net/ and Downloading from
https://sourceforge.net/projects/matplotlib/files/matplotlib/matplotlib-1.1.1/
3. Installing according to
http://matplotlib.sourceforge.net/users/installing.html
cd matplotlib
python setup.py build
python setup.py install
(I added sudo to make sure the files would be copied to the /usr....
directories)
ValueTool works fine on ubuntu 10.04 with both qwt and matplotlib
Thanks!
Agus
2012/7/25 Agustin Lobo <alobolistas at gmail.com>:
> Surprisingly, I get am error at installing the 0.4.0 version of
> valuetool on ubuntu 10.04:
> Couldn't load plugin valuetool due an error when calling its initGui() method
> Traceback (most recent call last):
>   File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 173, in
> startPlugin
>     plugins[packageName].initGui()
>   File "/home/alobo/.qgis//python/plugins/valuetool/valuetool.py",
> line 49, in initGui
>     self.valuewidget = ValueWidget(self.iface)
>   File "/home/alobo/.qgis//python/plugins/valuetool/valuewidget.py",
> line 51, in __init__
>     self.setupUi(self)
>   File "/home/alobo/.qgis//python/plugins/valuetool/valuewidgetbase.py",
> line 101, in setupUi
>     self.mplPlt.tick_params(axis='both', which='major', labelsize=12)
> AttributeError: 'AxesSubplot' object has no attribute 'tick_params'
> Python version:
> 2.6.5 (r265:79063, Apr 16 2010, 14:15:55)
> [GCC 4.4.3]
> QGIS version:
> 1.8.0-Lisboa Lisboa, exported
> Agus
> 2012/7/24 Agustin Lobo <alobolistas at gmail.com>:
>> Etienne,
>> 2012/7/24 Etienne Tourigny <etourigny.dev at gmail.com>:
>>> Uploaded 0.4.0 as experimental to the main plugin repos.  Those
>>> interested please test and report here or in the valuetool bugtracker.
>>> Also any feedback on the resolved bugs (#4905, #4798, #4796) is
>>> appreciated.
>> I've been out in the field for few days, sorry for coming late to this part of
>> the discussion.
>> MacOSX: The axes of the graph are drawn, but the following message:
>> "There are no statistics in the following rasters:
>> TTC1312v2
>> Calculate?"
>> is displayed over and over no matter the user answers Yes or No.
>> The user has to bring the message outside the map area (over the
>> Layers list) but then either answering Yes or No Qgis crashes.
>> If the user does not answer the message over the map area but brings
>> it to the Layer list area and then
>> answers either Yes or No, the graphic is displayed and the plugin works.
>> The matplotlib option is not present.
>> Linux (ubuntu 11:04). Plugin version 0.4.0
>> Works fine with both qwt and matplotlib, although much faster with Qwt
>> (but speed is not
>> a concern here, the graphics are displayed for thinking a while).
>> Answering Yes or No has the same consequence: the stats are calculated
>> and the graph is displayed
>> Linux (ubuntu 10:04): will test tomorrow at the office.
>> Many thanks!
>> Agus
