[Qgis-user] matplotlib not found on Mac OS
Agustin Lobo alobolistas at gmail.com
Wed Jul 25 01:52:28 PDT 2012
and do you have the option to select qwt or matplotlib?
Thanks
Agus
2012/7/25 Noli Sicad <nsicad at gmail.com>:
> Hi Agus,
> I activated in View -> Panels and I can see the graph (i.e x,y axis)
> when I checked the checkbox. I think this plugin is working in Lion
> which uses python 2.7.
> Are you using Snow Leopard?
> Noli
> On 7/25/12, Agustin Lobo <alobolistas at gmail.com> wrote:
>> Thanks Noli.
>> Go to View/Panels and you can activate it there.
>> Then display a multilayer raster and check both qwt and matplotlib.
>> If matplotlib is working for you then most likely is that I've done
>> something wrong in the installation.
>> Will check this evening and report back.
>> Agus
>>> I am using Mac OS X Lion.
>>> Installed Value Tool plugin, however, I don't not find the value tool
>>> menu.
>>> Where is it located?
>>> How to do you check if matplotlib is not find by value tool?
>>> I sucessfully installed contour plugin which use matplotlib and shapely.
>>> Noli
>>>> 2012/7/21 William Kyngesburye <woklist at kyngchaos.com>:
>>>>> On Jul 21, 2012, at 4:14 AM, Agustin Lobo wrote:
>>>>>> Also, some plugins such as statis complain about not having matplotlib
>>>>>> despite
>>>>>> it is installed.
>>>>> How did you install matplotlib?
>>>> I installed matplotlib following directions in
>>>> http://www.kyngchaos.com/software/python
>>>> and using the dmg provided there.
>>>> By some reason, while matplotlib is installed, qgis (and the new
>>>> version on valuetool which can use either qwt or matplotlib) cannot
>>>> find it.
>>>> I'm just a casual user of qgis on Mac, so please could any other more
>>>> experienced Mac user
>>>> help on testing this?
>>>> Thanks
>>>> Agus
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
