[Qgis-user] matplotlib not found on Mac OS
Noli Sicad nsicad at gmail.com
Wed Jul 25 02:01:08 PDT 2012
No.
There are 2 checkboxes on top: 1) Active (Shift + A) and 2) Graph
The Graph checkbox toogle: i)Graph and grid (Layer and Value).
Noli
On 7/25/12, Agustin Lobo <alobolistas at gmail.com> wrote:
> and do you have the option to select qwt or matplotlib?
> Thanks
> Agus
> 2012/7/25 Noli Sicad <nsicad at gmail.com>:
>> Hi Agus,
>> I activated in View -> Panels and I can see the graph (i.e x,y axis)
>> when I checked the checkbox. I think this plugin is working in Lion
>> which uses python 2.7.
>> Are you using Snow Leopard?
>> Noli
>>> Thanks Noli.
>>> Go to View/Panels and you can activate it there.
>>> Then display a multilayer raster and check both qwt and matplotlib.
>>> If matplotlib is working for you then most likely is that I've done
>>> something wrong in the installation.
>>> Will check this evening and report back.
>>> Agus
>>>> I am using Mac OS X Lion.
>>>> Installed Value Tool plugin, however, I don't not find the value tool
>>>> menu.
>>>> Where is it located?
>>>> How to do you check if matplotlib is not find by value tool?
>>>> I sucessfully installed contour plugin which use matplotlib and
>>>> shapely.
>>>> Noli
>>>>> 2012/7/21 William Kyngesburye <woklist at kyngchaos.com>:
>>>>>> On Jul 21, 2012, at 4:14 AM, Agustin Lobo wrote:
>>>>>>> Also, some plugins such as statis complain about not having
>>>>>>> matplotlib
>>>>>>> despite
>>>>>>> it is installed.
>>>>>> How did you install matplotlib?
>>>>> I installed matplotlib following directions in
>>>>> http://www.kyngchaos.com/software/python
>>>>> and using the dmg provided there.
>>>>> By some reason, while matplotlib is installed, qgis (and the new
>>>>> version on valuetool which can use either qwt or matplotlib) cannot
>>>>> find it.
>>>>> I'm just a casual user of qgis on Mac, so please could any other more
>>>>> experienced Mac user
>>>>> help on testing this?
>>>>> Thanks
>>>>> Agus
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
