[Qgis-user] matplotlib not found on Mac OS
Etienne Tourigny etourigny.dev at gmail.com
Wed Jul 25 02:16:00 PDT 2012
Most probably no checkbox - because no pyqwt! Are the dots in the
graph red (qwt) or blue (matplotlib) ?
Etienne
On Wed, Jul 25, 2012 at 6:01 AM, Noli Sicad <nsicad at gmail.com> wrote:
> No.
> There are 2 checkboxes on top: 1) Active (Shift + A) and 2) Graph
> The Graph checkbox toogle: i)Graph and grid (Layer and Value).
> Noli
> On 7/25/12, Agustin Lobo <alobolistas at gmail.com> wrote:
>> and do you have the option to select qwt or matplotlib?
>> Thanks
>> Agus
>> 2012/7/25 Noli Sicad <nsicad at gmail.com>:
>>> Hi Agus,
>>> I activated in View -> Panels and I can see the graph (i.e x,y axis)
>>> when I checked the checkbox. I think this plugin is working in Lion
>>> which uses python 2.7.
>>> Are you using Snow Leopard?
>>> Noli
>>>> Thanks Noli.
>>>> Go to View/Panels and you can activate it there.
>>>> Then display a multilayer raster and check both qwt and matplotlib.
>>>> If matplotlib is working for you then most likely is that I've done
>>>> something wrong in the installation.
>>>> Will check this evening and report back.
>>>> Agus
>>>>> I am using Mac OS X Lion.
>>>>> Installed Value Tool plugin, however, I don't not find the value tool
>>>>> menu.
>>>>> Where is it located?
>>>>> How to do you check if matplotlib is not find by value tool?
>>>>> I sucessfully installed contour plugin which use matplotlib and
>>>>> shapely.
>>>>> Noli
>>>>>> 2012/7/21 William Kyngesburye <woklist at kyngchaos.com>:
>>>>>>> On Jul 21, 2012, at 4:14 AM, Agustin Lobo wrote:
>>>>>>>> Also, some plugins such as statis complain about not having
>>>>>>>> matplotlib
>>>>>>>> despite
>>>>>>>> it is installed.
>>>>>>> How did you install matplotlib?
>>>>>> I installed matplotlib following directions in
>>>>>> http://www.kyngchaos.com/software/python
>>>>>> and using the dmg provided there.
>>>>>> By some reason, while matplotlib is installed, qgis (and the new
>>>>>> version on valuetool which can use either qwt or matplotlib) cannot
>>>>>> find it.
>>>>>> I'm just a casual user of qgis on Mac, so please could any other more
>>>>>> experienced Mac user
>>>>>> help on testing this?
>>>>>> Thanks
>>>>>> Agus
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
