[Qgis-user] matplotlib not found on Mac OS
Noli Sicad nsicad at gmail.com
Wed Jul 25 02:38:16 PDT 2012
I don't have a raster file right now. (This is new macbookpro). So a
can't check right now.
Noli
On 7/25/12, Etienne Tourigny <etourigny.dev at gmail.com> wrote:
> Most probably no checkbox - because no pyqwt! Are the dots in the
> graph red (qwt) or blue (matplotlib) ?
> Etienne
> On Wed, Jul 25, 2012 at 6:01 AM, Noli Sicad <nsicad at gmail.com> wrote:
>> No.
>> There are 2 checkboxes on top: 1) Active (Shift + A) and 2) Graph
>> The Graph checkbox toogle: i)Graph and grid (Layer and Value).
>> Noli
>> On 7/25/12, Agustin Lobo <alobolistas at gmail.com> wrote:
>>> and do you have the option to select qwt or matplotlib?
>>> Thanks
>>> Agus
>>> 2012/7/25 Noli Sicad <nsicad at gmail.com>:
>>>> Hi Agus,
>>>> I activated in View -> Panels and I can see the graph (i.e x,y axis)
>>>> when I checked the checkbox. I think this plugin is working in Lion
>>>> which uses python 2.7.
>>>> Are you using Snow Leopard?
>>>> Noli
>>>>> Thanks Noli.
>>>>> Go to View/Panels and you can activate it there.
>>>>> Then display a multilayer raster and check both qwt and matplotlib.
>>>>> If matplotlib is working for you then most likely is that I've done
>>>>> something wrong in the installation.
>>>>> Will check this evening and report back.
>>>>> Agus
>>>>>> I am using Mac OS X Lion.
>>>>>> Installed Value Tool plugin, however, I don't not find the value tool
>>>>>> menu.
>>>>>> Where is it located?
>>>>>> How to do you check if matplotlib is not find by value tool?
>>>>>> I sucessfully installed contour plugin which use matplotlib and
>>>>>> shapely.
>>>>>> Noli
>>>>>>> 2012/7/21 William Kyngesburye <woklist at kyngchaos.com>:
>>>>>>>> On Jul 21, 2012, at 4:14 AM, Agustin Lobo wrote:
>>>>>>>>> Also, some plugins such as statis complain about not having
>>>>>>>>> matplotlib
>>>>>>>>> despite
>>>>>>>>> it is installed.
>>>>>>>> How did you install matplotlib?
>>>>>>> I installed matplotlib following directions in
>>>>>>> http://www.kyngchaos.com/software/python
>>>>>>> and using the dmg provided there.
>>>>>>> By some reason, while matplotlib is installed, qgis (and the new
>>>>>>> version on valuetool which can use either qwt or matplotlib) cannot
>>>>>>> find it.
>>>>>>> I'm just a casual user of qgis on Mac, so please could any other
>>>>>>> more
>>>>>>> experienced Mac user
>>>>>>> help on testing this?
>>>>>>> Thanks
>>>>>>> Agus
>>>>>>> _______________________________________________
>>>>>>> Qgis-user mailing list
>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
