[Qgis-user] matplotlib not found on Mac OS
Agustin Lobo alobolistas at gmail.com
Wed Jul 25 02:51:54 PDT 2012
use this:
http://dl.dropbox.com/u/3180464/AFNDVI.tif
Agus
2012/7/25 Noli Sicad <nsicad at gmail.com>:
> I don't have a raster file right now. (This is new macbookpro). So a
> can't check right now.
> Noli
> On 7/25/12, Etienne Tourigny <etourigny.dev at gmail.com> wrote:
>> Most probably no checkbox - because no pyqwt! Are the dots in the
>> graph red (qwt) or blue (matplotlib) ?
>> Etienne
>> On Wed, Jul 25, 2012 at 6:01 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>> No.
>>> There are 2 checkboxes on top: 1) Active (Shift + A) and 2) Graph
>>> The Graph checkbox toogle: i)Graph and grid (Layer and Value).
>>> Noli
>>> On 7/25/12, Agustin Lobo <alobolistas at gmail.com> wrote:
>>>> and do you have the option to select qwt or matplotlib?
>>>> Thanks
>>>> Agus
>>>>> Hi Agus,
>>>>> I activated in View -> Panels and I can see the graph (i.e x,y axis)
>>>>> when I checked the checkbox. I think this plugin is working in Lion
>>>>> which uses python 2.7.
>>>>> Are you using Snow Leopard?
>>>>> Noli
>>>>>> Thanks Noli.
>>>>>> Go to View/Panels and you can activate it there.
>>>>>> Then display a multilayer raster and check both qwt and matplotlib.
>>>>>> If matplotlib is working for you then most likely is that I've done
>>>>>> something wrong in the installation.
>>>>>> Will check this evening and report back.
>>>>>> Agus
>>>>>>> I am using Mac OS X Lion.
>>>>>>> Installed Value Tool plugin, however, I don't not find the value tool
>>>>>>> menu.
>>>>>>> Where is it located?
>>>>>>> How to do you check if matplotlib is not find by value tool?
>>>>>>> I sucessfully installed contour plugin which use matplotlib and
>>>>>>> shapely.
>>>>>>> Noli
>>>>>>>> 2012/7/21 William Kyngesburye <woklist at kyngchaos.com>:
>>>>>>>>> On Jul 21, 2012, at 4:14 AM, Agustin Lobo wrote:
>>>>>>>>>> Also, some plugins such as statis complain about not having
>>>>>>>>>> matplotlib
>>>>>>>>>> despite
>>>>>>>>>> it is installed.
>>>>>>>>> How did you install matplotlib?
>>>>>>>> I installed matplotlib following directions in
>>>>>>>> http://www.kyngchaos.com/software/python
>>>>>>>> and using the dmg provided there.
>>>>>>>> By some reason, while matplotlib is installed, qgis (and the new
>>>>>>>> version on valuetool which can use either qwt or matplotlib) cannot
>>>>>>>> find it.
>>>>>>>> I'm just a casual user of qgis on Mac, so please could any other
>>>>>>>> more
>>>>>>>> experienced Mac user
>>>>>>>> help on testing this?
>>>>>>>> Thanks
>>>>>>>> Agus
>>>>>>>> _______________________________________________
>>>>>>>> Qgis-user mailing list
>>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
