[Qgis-user] matplotlib not found on Mac OS
Noli Sicad nsicad at gmail.com
Wed Jul 25 03:05:57 PDT 2012
Hi Agus,
Thanks for this tif file.
However, when check ( )Active (Shif +A).
I got this message:
"There are no statistics in the following rasters:
AFNDVI
Calculate?
No and Yes
When I selected Yes. Stiill the message box would go away.
The same with No.
What must be the problem?
Noli
On 7/25/12, Agustin Lobo <alobolistas at gmail.com> wrote:
> use this:
> http://dl.dropbox.com/u/3180464/AFNDVI.tif
> Agus
> 2012/7/25 Noli Sicad <nsicad at gmail.com>:
>> I don't have a raster file right now. (This is new macbookpro). So a
>> can't check right now.
>> Noli
>> On 7/25/12, Etienne Tourigny <etourigny.dev at gmail.com> wrote:
>>> Most probably no checkbox - because no pyqwt! Are the dots in the
>>> graph red (qwt) or blue (matplotlib) ?
>>> Etienne
>>> On Wed, Jul 25, 2012 at 6:01 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>>> No.
>>>> There are 2 checkboxes on top: 1) Active (Shift + A) and 2) Graph
>>>> The Graph checkbox toogle: i)Graph and grid (Layer and Value).
>>>> Noli
>>>>> and do you have the option to select qwt or matplotlib?
>>>>> Thanks
>>>>> Agus
>>>>>> Hi Agus,
>>>>>> I activated in View -> Panels and I can see the graph (i.e x,y axis)
>>>>>> when I checked the checkbox. I think this plugin is working in Lion
>>>>>> which uses python 2.7.
>>>>>> Are you using Snow Leopard?
>>>>>> Noli
>>>>>>> Thanks Noli.
>>>>>>> Go to View/Panels and you can activate it there.
>>>>>>> Then display a multilayer raster and check both qwt and matplotlib.
>>>>>>> If matplotlib is working for you then most likely is that I've done
>>>>>>> something wrong in the installation.
>>>>>>> Will check this evening and report back.
>>>>>>> Agus
>>>>>>>> I am using Mac OS X Lion.
>>>>>>>> Installed Value Tool plugin, however, I don't not find the value
>>>>>>>> tool
>>>>>>>> menu.
>>>>>>>> Where is it located?
>>>>>>>> How to do you check if matplotlib is not find by value tool?
>>>>>>>> I sucessfully installed contour plugin which use matplotlib and
>>>>>>>> shapely.
>>>>>>>> Noli
>>>>>>>>> 2012/7/21 William Kyngesburye <woklist at kyngchaos.com>:
>>>>>>>>>> On Jul 21, 2012, at 4:14 AM, Agustin Lobo wrote:
>>>>>>>>>>> Also, some plugins such as statis complain about not having
>>>>>>>>>>> matplotlib
>>>>>>>>>>> despite
>>>>>>>>>>> it is installed.
>>>>>>>>>> How did you install matplotlib?
>>>>>>>>> I installed matplotlib following directions in
>>>>>>>>> http://www.kyngchaos.com/software/python
>>>>>>>>> and using the dmg provided there.
>>>>>>>>> By some reason, while matplotlib is installed, qgis (and the new
>>>>>>>>> version on valuetool which can use either qwt or matplotlib)
>>>>>>>>> cannot
>>>>>>>>> find it.
>>>>>>>>> I'm just a casual user of qgis on Mac, so please could any other
>>>>>>>>> more
>>>>>>>>> experienced Mac user
>>>>>>>>> help on testing this?
>>>>>>>>> Thanks
>>>>>>>>> Agus
>>>>>>>>> _______________________________________________
>>>>>>>>> Qgis-user mailing list
>>>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
