[Qgis-user] matplotlib not found on Mac OS
Noli Sicad nsicad at gmail.com
Wed Jul 25 03:43:47 PDT 2012
Hi Agus,
OK.
It is working now.
I got the blue dots with lines when I hover into the tiff map.
Do this means that matplotlib is working, right?
Noli
On 7/25/12, Agustin Lobo <Agustin.Lobo at ictja.csic.es> wrote:
> ok, you are finding the same problem than I, please read my
> original message: move the message window outside the map area and
> click either Yes or No
> Agus
> On Wed, Jul 25, 2012 at 12:05 PM, Noli Sicad <nsicad at gmail.com> wrote:
>> Hi Agus,
>> Thanks for this tif file.
>> However, when check ( )Active (Shif +A).
>> I got this message:
>> "There are no statistics in the following rasters:
>> AFNDVI
>> Calculate?
>> No and Yes
>> When I selected Yes. Stiill the message box would go away.
>> The same with No.
>> What must be the problem?
>> Noli
>> On 7/25/12, Agustin Lobo <alobolistas at gmail.com> wrote:
>>> use this:
>>> http://dl.dropbox.com/u/3180464/AFNDVI.tif
>>> Agus
>>> 2012/7/25 Noli Sicad <nsicad at gmail.com>:
>>>> I don't have a raster file right now. (This is new macbookpro). So a
>>>> can't check right now.
>>>> Noli
>>>> On 7/25/12, Etienne Tourigny <etourigny.dev at gmail.com> wrote:
>>>>> Most probably no checkbox - because no pyqwt! Are the dots in the
>>>>> graph red (qwt) or blue (matplotlib) ?
>>>>> Etienne
>>>>> On Wed, Jul 25, 2012 at 6:01 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>>>>> No.
>>>>>> There are 2 checkboxes on top: 1) Active (Shift + A) and 2) Graph
>>>>>> The Graph checkbox toogle: i)Graph and grid (Layer and Value).
>>>>>> Noli
>>>>>>> and do you have the option to select qwt or matplotlib?
>>>>>>> Thanks
>>>>>>> Agus
>>>>>>>> Hi Agus,
>>>>>>>> I activated in View -> Panels and I can see the graph (i.e x,y
>>>>>>>> axis)
>>>>>>>> when I checked the checkbox. I think this plugin is working in Lion
>>>>>>>> which uses python 2.7.
>>>>>>>> Are you using Snow Leopard?
>>>>>>>> Noli
>>>>>>>>> Thanks Noli.
>>>>>>>>> Go to View/Panels and you can activate it there.
>>>>>>>>> Then display a multilayer raster and check both qwt and
>>>>>>>>> matplotlib.
>>>>>>>>> If matplotlib is working for you then most likely is that I've
>>>>>>>>> done
>>>>>>>>> something wrong in the installation.
>>>>>>>>> Will check this evening and report back.
>>>>>>>>> Agus
>>>>>>>>>> I am using Mac OS X Lion.
>>>>>>>>>> Installed Value Tool plugin, however, I don't not find the value
>>>>>>>>>> tool
>>>>>>>>>> menu.
>>>>>>>>>> Where is it located?
>>>>>>>>>> How to do you check if matplotlib is not find by value tool?
>>>>>>>>>> I sucessfully installed contour plugin which use matplotlib and
>>>>>>>>>> shapely.
>>>>>>>>>> Noli
>>>>>>>>>>> 2012/7/21 William Kyngesburye <woklist at kyngchaos.com>:
>>>>>>>>>>>> On Jul 21, 2012, at 4:14 AM, Agustin Lobo wrote:
>>>>>>>>>>>>> Also, some plugins such as statis complain about not having
>>>>>>>>>>>>> matplotlib
>>>>>>>>>>>>> despite
>>>>>>>>>>>>> it is installed.
>>>>>>>>>>>> How did you install matplotlib?
>>>>>>>>>>> I installed matplotlib following directions in
>>>>>>>>>>> http://www.kyngchaos.com/software/python
>>>>>>>>>>> and using the dmg provided there.
>>>>>>>>>>> By some reason, while matplotlib is installed, qgis (and the new
>>>>>>>>>>> version on valuetool which can use either qwt or matplotlib)
>>>>>>>>>>> cannot
>>>>>>>>>>> find it.
>>>>>>>>>>> I'm just a casual user of qgis on Mac, so please could any other
>>>>>>>>>>> more
>>>>>>>>>>> experienced Mac user
>>>>>>>>>>> help on testing this?
>>>>>>>>>>> Thanks
>>>>>>>>>>> Agus
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> Qgis-user mailing list
>>>>>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Dr. Agustin Lobo
> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
> Lluis Sole Sabaris s/n
> 08028 Barcelona
> Spain
> Tel. 34 934095410
> Fax. 34 934110012
> e-mail Agustin.Lobo at ictja.csic.es
> https://sites.google.com/site/aloboaleu/
