[Qgis-user] Problem with GdalTools and python-gdal 1.9 on ubuntu 10:04
Agustin Lobo alobolistas at gmail.com
Wed Jul 25 02:39:45 PDT 2012
I found the reason and the fix:
I had several old (2010)  libgdal* files (including libgdal.so.*) in
/usr/local/lib masking the new ones in /usr/lib
Deleting (actually moving them to another directory just in case) the
ones in /usr/local/lib
makes a clean start up of qgis.
Agus
2012/7/25 Agustin Lobo <alobolistas at gmail.com>:
> Using qgis 1.8 on ubuntu 10.04
> I've upgraded to python-gdal 1.9 and the GdalTools plugin and some others
> complain at qgis start-up:
> Couldn't load plugin openlayers due an error when calling its
> classFactory() method
> Traceback (most recent call last):
>   File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 164, in
> startPlugin
>     plugins[packageName] = package.classFactory(iface)
>   File "/home/alobo/.qgis//python/plugins/openlayers/__init__.py",
> line 48, in classFactory
>     from openlayers_plugin import OpenlayersPlugin
>   File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 309, in _import
>     mod = _builtin_import(name, globals, locals, fromlist, level)
>   File "/home/alobo/.qgis//python/plugins/openlayers/openlayers_plugin.py",
> line 35, in
>     from openlayers_ovwidget import OpenLayersOverviewWidget
>   File "/home/alobo/.qgis//python/plugins/openlayers/openlayers_ovwidget.py",
> line 28, in
>     import bindogr
>   File "/home/alobo/.qgis//python/plugins/openlayers/bindogr.py", line 1, in
>     from osgeo import ogr, osr
>   File "/usr/lib/python2.6/dist-packages/osgeo/__init__.py", line 21, in
>     _gdal = swig_import_helper()
>   File "/usr/lib/python2.6/dist-packages/osgeo/__init__.py", line 17,
> in swig_import_helper
>     _mod = imp.load_module('_gdal', fp, pathname, description)
> ImportError: /usr/lib/python2.6/dist-packages/osgeo/_gdal.so: symbol
> VSIFTruncateL, version GDAL_1.8 not defined in file libgdal.so.1 with
> link time reference
> Python version:
> 2.6.5 (r265:79063, Apr 16 2010, 14:15:55)
> [GCC 4.4.3]
> I had circumvented this issue by forcin python-gdal 1.8, but this
> version is no longer available.
> Any solution to this problem?
> Thanks
> Agus
