[Qgis-user] Problem with GdalTools and python-gdal 1.9 on ubuntu 10:04
Etienne Tourigny etourigny.dev at gmail.com
Wed Jul 25 04:19:12 PDT 2012
that happens when you install gdal-1.9 on top of gdal-1.8 without
removing the 1.8 files first.
Etienne
On Wed, Jul 25, 2012 at 6:39 AM, Agustin Lobo <alobolistas at gmail.com> wrote:
> I found the reason and the fix:
> I had several old (2010)  libgdal* files (including libgdal.so.*) in
> /usr/local/lib masking the new ones in /usr/lib
> Deleting (actually moving them to another directory just in case) the
> ones in /usr/local/lib
> makes a clean start up of qgis.
> Agus
> 2012/7/25 Agustin Lobo <alobolistas at gmail.com>:
>> Using qgis 1.8 on ubuntu 10.04
>> I've upgraded to python-gdal 1.9 and the GdalTools plugin and some others
>> complain at qgis start-up:
>> Couldn't load plugin openlayers due an error when calling its
>> classFactory() method
>> Traceback (most recent call last):
>>   File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 164, in
>> startPlugin
>>     plugins[packageName] = package.classFactory(iface)
>>   File "/home/alobo/.qgis//python/plugins/openlayers/__init__.py",
>> line 48, in classFactory
>>     from openlayers_plugin import OpenlayersPlugin
>>   File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 309, in _import
>>     mod = _builtin_import(name, globals, locals, fromlist, level)
>>   File "/home/alobo/.qgis//python/plugins/openlayers/openlayers_plugin.py",
>> line 35, in
>>     from openlayers_ovwidget import OpenLayersOverviewWidget
>>   File "/home/alobo/.qgis//python/plugins/openlayers/openlayers_ovwidget.py",
>> line 28, in
>>     import bindogr
>>   File "/home/alobo/.qgis//python/plugins/openlayers/bindogr.py", line 1, in
>>     from osgeo import ogr, osr
>>   File "/usr/lib/python2.6/dist-packages/osgeo/__init__.py", line 21, in
>>     _gdal = swig_import_helper()
>>   File "/usr/lib/python2.6/dist-packages/osgeo/__init__.py", line 17,
>> in swig_import_helper
>>     _mod = imp.load_module('_gdal', fp, pathname, description)
>> ImportError: /usr/lib/python2.6/dist-packages/osgeo/_gdal.so: symbol
>> VSIFTruncateL, version GDAL_1.8 not defined in file libgdal.so.1 with
>> link time reference
>> Python version:
>> 2.6.5 (r265:79063, Apr 16 2010, 14:15:55)
>> [GCC 4.4.3]
>> I had circumvented this issue by forcin python-gdal 1.8, but this
>> version is no longer available.
>> Any solution to this problem?
>> Thanks
>> Agus
> Qgis-user mailing list
