[Qgis-user] Problems SAGA GIS module in SEXTANTE
Corina Tudorache corina_ww at yahoo.com
Wed Jul 25 03:15:40 PDT 2012
I encountered some problems when I tried  to use the SAGA module in SEXTANTE in the 1.8.0. version of Qgis. More precise, the SAGA module doesn't exist, I receive an error message... . Does anyone know how to solve this problem?
Thanks in advance,
Corina
 From: "qgis-user-request at lists.osgeo.org" <qgis-user-request at lists.osgeo.org>
To: qgis-user at lists.osgeo.org
Sent: Wednesday, July 25, 2012 12:51 PM
Subject: Qgis-user Digest, Vol 77, Issue 82
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
    http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
    qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-user digest..."
Today's Topics:
   1. Problem with GdalTools and python-gdal 1.9 on ubuntu    10:04
      (Agustin Lobo)
   2. Re: matplotlib not found on Mac OS (Noli Sicad)
   3. Re: matplotlib not found on Mac OS (Etienne Tourigny)
   4. Re: matplotlib not found on Mac OS (Noli Sicad)
   5. Re: Problem with GdalTools and python-gdal 1.9 on    ubuntu
      10:04 (Agustin Lobo)
   6. Re: matplotlib not found on Mac OS (Agustin Lobo)
Message: 1
Date: Wed, 25 Jul 2012 10:55:16 +0200
To: qgis-user <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Problem with GdalTools and python-gdal 1.9 on
    ubuntu    10:04
Message-ID:
    <CAG4NReJwtDUR+3TUHchiT8a2DSbUkaJBmZGvR8pPCtdpAS6G6w at mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
Using qgis 1.8 on ubuntu 10.04
I've upgraded to python-gdal 1.9 and the GdalTools plugin and some others
complain at qgis start-up:
Couldn't load plugin openlayers due an error when calling its
classFactory() method
  File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 164, in
startPlugin
    plugins[packageName] = package.classFactory(iface)
  File "/home/alobo/.qgis//python/plugins/openlayers/__init__.py",
line 48, in classFactory
    from openlayers_plugin import OpenlayersPlugin
  File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 309, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "/home/alobo/.qgis//python/plugins/openlayers/openlayers_plugin.py",
line 35, in
    from openlayers_ovwidget import OpenLayersOverviewWidget
  File "/home/alobo/.qgis//python/plugins/openlayers/openlayers_ovwidget.py",
line 28, in
    import bindogr
  File "/home/alobo/.qgis//python/plugins/openlayers/bindogr.py", line 1, in
    from osgeo import ogr, osr
  File "/usr/lib/python2.6/dist-packages/osgeo/__init__.py", line 21, in
    _gdal = swig_import_helper()
  File "/usr/lib/python2.6/dist-packages/osgeo/__init__.py", line 17,
in swig_import_helper
    _mod = imp.load_module('_gdal', fp, pathname, description)
ImportError: /usr/lib/python2.6/dist-packages/osgeo/_gdal.so: symbol
VSIFTruncateL, version GDAL_1.8 not defined in file libgdal.so.1 with
link time reference
Python version:
2.6.5 (r265:79063, Apr 16 2010, 14:15:55)
[GCC 4.4.3]
I had circumvented this issue by forcin python-gdal 1.8, but this
version is no longer available.
Any solution to this problem?
Thanks
Agus
Message: 2
Date: Wed, 25 Jul 2012 19:01:08 +1000
To: Agustin.Lobo at ictja.csic.es
Cc: qgis-user <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] matplotlib not found on Mac OS
Message-ID:
    <CADs9uc_6Z=3S-BM4GG3+VehkK6i_CoPMOiwmWBkU7ouOmha1KA at mail.gmail.com>
No.
There are 2 checkboxes on top: 1) Active (Shift + A) and 2) Graph
The Graph checkbox toogle: i)Graph and grid (Layer and Value).
Noli
On 7/25/12, Agustin Lobo <alobolistas at gmail.com> wrote:
> and do you have the option to select qwt or matplotlib?
> Thanks
> Agus
> 2012/7/25 Noli Sicad <nsicad at gmail.com>:
>> Hi Agus,
>> I activated in View -> Panels and I can see the graph (i.e x,y axis)
>> when I checked the checkbox. I think this plugin is working in Lion
>> which uses python 2.7.
>> Are you using Snow Leopard?
>> Noli
>>> Thanks Noli.
>>> Go to View/Panels and you can activate it there.
>>> Then display a multilayer raster and check both qwt and matplotlib.
>>> If matplotlib is working for you then most likely is that I've done
>>> something wrong in the installation.
>>> Will check this evening and report back.
>>> Agus
>>>> I am using Mac OS X Lion.
>>>> Installed Value Tool plugin, however, I don't not find the value tool
>>>> menu.
>>>> Where is it located?
>>>> How to do you check if matplotlib is not find by value tool?
>>>> I sucessfully installed contour plugin which use matplotlib and
>>>> shapely.
>>>> Noli
>>>>> 2012/7/21 William Kyngesburye <woklist at kyngchaos.com>:
>>>>>> On Jul 21, 2012, at 4:14 AM, Agustin Lobo wrote:
>>>>>>> Also, some plugins such as statis complain about not having
>>>>>>> matplotlib
>>>>>>> despite
>>>>>>> it is installed.
>>>>>> How did you install matplotlib?
>>>>> I installed matplotlib following directions in
>>>>> http://www.kyngchaos.com/software/python
>>>>> and using the dmg provided there.
>>>>> By some reason, while matplotlib is installed, qgis (and the new
>>>>> version on valuetool which can use either qwt or matplotlib) cannot
>>>>> find it.
>>>>> I'm just a casual user of qgis on Mac, so please could any other more
>>>>> experienced Mac user
>>>>> help on testing this?
>>>>> Thanks
>>>>> Agus
>>>>> _______________________________________________
>>>>> Qgis-user at lists.osgeo.org
Message: 3
Date: Wed, 25 Jul 2012 06:16:00 -0300
From: Etienne Tourigny <etourigny.dev at gmail.com>
To: Noli Sicad <nsicad at gmail.com>
Cc: Agustin.Lobo at ictja.csic.es, qgis-user <qgis-user at lists.osgeo.org>
Message-ID:
    <CA+TxYvMCpm7tuEJuwhk00fF7zU+bQmNi39=LjjOZxAq9Lq6gCA at mail.gmail.com>
Most probably no checkbox - because no pyqwt! Are the dots in the
graph red (qwt) or blue (matplotlib) ?
Etienne
On Wed, Jul 25, 2012 at 6:01 AM, Noli Sicad <nsicad at gmail.com> wrote:
> No.
> Noli
>> Thanks
>> Agus
>>> Hi Agus,
>>> Noli
>>>> Thanks Noli.
>>>> Agus
>>>>> menu.
>>>>> shapely.
>>>>> Noli
>>>>>>>> matplotlib
>>>>>>>> despite
>>>>>>>> it is installed.
>>>>>> find it.
>>>>>> Thanks
>>>>>> Agus
Message: 4
Date: Wed, 25 Jul 2012 19:38:16 +1000
To: Etienne Tourigny <etourigny.dev at gmail.com>
Message-ID:
    <CADs9uc93wYxBaEESGRCgitKPYOHq6wcZMdHKXPiP-KQ0RLQvYA at mail.gmail.com>
I don't have a raster file right now. (This is new macbookpro). So a
can't check right now.
Noli
> Etienne
>> No.
>> Noli
>>> Thanks
>>> Agus
>>>> Hi Agus,
>>>> Noli
>>>>> Thanks Noli.
>>>>> Agus
>>>>>> menu.
>>>>>> shapely.
>>>>>> Noli
>>>>>>>>> matplotlib
>>>>>>>>> despite
>>>>>>>>> it is installed.
>>>>>>> find it.
>>>>>>> more
>>>>>>> Thanks
>>>>>>> Agus
Message: 5
Date: Wed, 25 Jul 2012 11:39:45 +0200
Subject: Re: [Qgis-user] Problem with GdalTools and python-gdal 1.9 on
    ubuntu 10:04
Message-ID:
    <CAG4NReJKwAC1Roksbq4fW27vPEk-F3xFW648W=2=cq87czFQyA at mail.gmail.com>
I found the reason and the fix:
I had several old (2010)  libgdal* files (including libgdal.so.*) in
/usr/local/lib masking the new ones in /usr/lib
Deleting (actually moving them to another directory just in case) the
ones in /usr/local/lib
makes a clean start up of qgis.
Agus
2012/7/25 Agustin Lobo <alobolistas at gmail.com>:
> startPlugin
> line 35, in
> line 28, in
>     import bindogr
> link time reference
> Python version:
> [GCC 4.4.3]
> Thanks
> Agus
Message: 6
Date: Wed, 25 Jul 2012 11:51:54 +0200
Message-ID:
    <CAG4NReJbzuhjHaih1yE6Gnuyrwgj=-8QDMJ3peP8cKbafxKX7A at mail.gmail.com>
use this:
http://dl.dropbox.com/u/3180464/AFNDVI.tif
Agus
> Noli
>> Etienne
>>> No.
>>> Noli
>>>> Thanks
>>>> Agus
>>>>> Hi Agus,
>>>>> Noli
>>>>>> Thanks Noli.
>>>>>> Agus
>>>>>>> menu.
>>>>>>> shapely.
>>>>>>> Noli
>>>>>>>>>> matplotlib
>>>>>>>>>> despite
>>>>>>>>>> it is installed.
>>>>>>>> find it.
>>>>>>>> more
>>>>>>>> Thanks
>>>>>>>> Agus
End of Qgis-user Digest, Vol 77, Issue 82
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120725/35fa2102/attachment.html>
