[Qgis-user] matplotlib not found on Mac OS
Agustin Lobo alobolistas at gmail.com
Wed Jul 25 11:44:58 PDT 2012
I reinstalled matplotlib from
http://www.kyngchaos.com/software/python and the installation of
statis was successful.
(Mac OS 10.7.4)
Thanks
Agus
2012/7/25 Agustin Lobo <alobolistas at gmail.com>:
> Thanks Noli.
> Go to View/Panels and you can activate it there.
> Then display a multilayer raster and check both qwt and matplotlib.
> If matplotlib is working for you then most likely is that I've done
> something wrong in the installation.
> Will check this evening and report back.
> Agus
> 2012/7/25 Noli Sicad <nsicad at gmail.com>:
>> I am using Mac OS X Lion.
>> Installed Value Tool plugin, however, I don't not find the value tool menu.
>> Where is it located?
>> How to do you check if matplotlib is not find by value tool?
>> I sucessfully installed contour plugin which use matplotlib and shapely.
>> Noli
>> On 7/25/12, Agustin Lobo <alobolistas at gmail.com> wrote:
>>> 2012/7/21 William Kyngesburye <woklist at kyngchaos.com>:
>>>> On Jul 21, 2012, at 4:14 AM, Agustin Lobo wrote:
>>>>> Also, some plugins such as statis complain about not having matplotlib
>>>>> despite
>>>>> it is installed.
>>>> How did you install matplotlib?
>>> I installed matplotlib following directions in
>>> and using the dmg provided there.
>>> By some reason, while matplotlib is installed, qgis (and the new
>>> version on valuetool which can use either qwt or matplotlib) cannot
>>> find it.
>>> I'm just a casual user of qgis on Mac, so please could any other more
>>> experienced Mac user
>>> help on testing this?
>>> Thanks
>>> Agus
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
